EM05-G eSIM under Win 11 - full instructions
Please provide more detailed instructions for how to enable the eSim for EM05-G M.2 module under Windows 11. I see the post here: Quectel EM05-G eSIM activation problem
It mentions the command AT+QSIMCFG=“disable_physim”,0,0
But I can’t see any documentation at all about this command in the AT command manual.
Please provide the full documentation for what options this command supports. I’m concerned that after I send that command, it may not be able to use conventional SIM’s, and I may need to undo the setting. Without proper documentation, I don’t know how.
Also please send the latest firmware update for EM05-G along with Windows firmware update tools.
Hi @esisChris ,
Sent to your email please check.
Thanks, received the firmware and application note.
Meanwhile I have been in touch with Quectel support in Australia, they informed me that the EM05-G does not have an eSIM eUICC chip inside it, so it requires an external eUICC in the form of a standard plastic SIM card, to be inserted in the SIM slot, then the module will support loading eSIM profiles etc.
Hello @Hayes ,
I think I need the latest firmware update for EM05-G along with Windows firmware update tool too, I found this post, AT+QSIMCFG=“disable_physim”,0,0, but my EM05-G didn’t support.
Please help me on that, thanksyou.
Hi, Bruce. I have sent the latest firmware and Windows update tool to your inbox, pls chk, thanku.
