EG915U not getting IP address
We are using EG915 and connect it to raspberry over the USB interface
The device occurs on ifconfig, but there is no IP. The device is in default ECM mode.
usb0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 02:4b:b3:b9:eb:e5 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
Right now the sim card is in Roaming mode. I am checking the state with:
sudo minicom -D /dev/ttyUSB0
AT
AT+CFUN?
+CFUN: 1
AT+COPS?
+COPS: 0,0,“vodafone.de”,0
AT+CPIN?
+CPIN: READY
AT+CREG?
+CREG: 2,5,“0134”,“282A”,0
AT+QNWINFO
+QNWINFO: “GPRS”,“26202”,“GSM 900”,3
AT+QCFG=“usbnet”
+QCFG: “usbnet”,1
AT+CGATT?
+CGATT: 1
AT+CGDCONT?
+CGDCONT: 1,“IP”,“internet”,“0.0.0.0”,0,0
AT+CEREG?
+CEREG: 0,0
Can you please help to fix the problem that the device does not get the IP address and there is no communication?
You need to send the AT command
AT+QNETDEVCTL=1,1,1
and then run DHCP
busybox udhcpc -i usb0
First you need to register on the LTE network and then “dial” as shown above.
Thank you. Can you please write how to force to register to LTE network?
I would use +cops to list networks and technologies available and disable all fhe RATs except LTE.
With AT+COPS=? I am getting this:
AT+COPS=?
+COPS: (1,“o2 - de”,“o2 - de”,“26203”,0),(1,“vodafone.de”,“Vodafone”,“26202”,0),(1,“Telekom.de”,“TDG”,“26201”,0),(0-4))
It seems this is 2G only? I will move around the city. However, shouldn’t IP assignment also work on 2G?
Yes, 0 is the Access Technology that is available, 0 is GSM and 7 is E-UTRAN.
Make sure you have the proper antenna attached and check the output of
AT+QCFG="band"
AT+QCFG="nwscanmode"
Please use </> button to format the terminal output.
Thank you for your answer. I moved to the city center, however there seems to be less networks. At the moment I only have Molex flexible antenna 824-2170MHz, serial number 207235.
The answers from the “band” and “nwscanmode” are below:
AT+CGATT?
+CGATT: 1
AT+CEREG?
+CEREG: 0,0
AT+QCFG="band"
+QCFG: "band",0xf,0x80800d5
+QCFG: "nwscanmode",0
AT+COPS=?
+COPS: (2,"vodafone.de","Vodafone","26202",0),,(0-4),(0-2)
Based on this I suppose, I have to change it to EU bands:
AT+QCFG="band",3,800015,1
+CREG: 0
+CREG: 2,"0134","282A",0
+CREG: 5,"0134","282A",0
+CGREG: 5,"0134","282A",0
After this I get response, which seems the B20 was not set for some reason
AT+QCFG="band"
+QCFG: "band",0x3,0x15
AT+QNETDEVCTL=1,1,1
+QNETDEVSTATUS: 0
AT+QNETDEVCTL?
+QNETDEVCTL: 0,0,0,0
That’s absolutely fine - 0x80800d5 corresponds to LTE bands “B1 B3 B5 B7 B8 B20 B28”, there is no reason to change it.
Ok, I changed it back:
AT+QCFG="band",3,80800d5,1
+CGREG: 0
+CREG: 0
+CGREG: 2,"0134","282A",0
AT+QCFG="band"
+QCFG: "band",0x3,0x80800d5
Would you have any additional suggestion?
Any chance to test with the local SIM?
I don’t currently see a reason why it cannot see any LTE network.
See also No ip configuration
Thank you. At the moment I cant test with local simcard. I can do with local SIM in another country tomorrow.
I also did some commands from your mentioned link:
AT+QNETDEVCTL?
+QNETDEVCTL: 3,2,0,0
So this one seems states automatic connection to network. And the PDP context is 2. I think it should be 1? However, it seems that I cannot change it.
AT+QNETDEVCTL=3,1,1
+CME ERROR: 53
AT+CGACT=0,2
AT+CGACT=1,1
+CME ERROR: 3
AT+CGDCONT?
+CGDCONT: 1,"IP","internet","0.0.0.0",0,0
+CGDCONT: 2,"IP","","0.0.0.0",0,0
AT+QENG="servingcell"
+QENG: "servingcell","NOCONN","GSM",262,02,134,282A,58,3,2,13,5,97,0,9,9,-,-,-,-,-,-,-,-,-,-,"-"
AT+QNWINFO
+QNWINFO: "GPRS","26202","GSM 900",3
Estou precisando dos Drivers USB Quectel (EG915 compatível)** inbox_tray Download oficial — Quectel_USB_Driver_V2.0, e QFlash Tool v5.3
