EG915U-EU Voice Call Support in LTE mode
I see a problem with incoming Voice Call support in EG915U-EU module.
When the module is in GSM network, an incoming voice call results in +CRING, +CLIP notifications as it should be:
18:42:49.807, +QCSQ: “GSM”,-106
++incoming call initiated here++
18:42:56.928, +CRING: VOICE
18:42:56.928,
18:42:56.990, +CLIP: “xxxxxxxxx”,145,0,0
18:42:56.990, ATH0
18:42:57.490,
18:42:57.490, OK
But in LTE mode, no such notifications are visible, and only fallback to GSM mode (for 3 seconds) is notified:
18:40:45.679, +QCSQ: “LTE”,95,-128,39,-15 ← operating in LTE
18:40:55.619, +CREG: 2,1,“0071”,“014E934”,7
18:40:55.931, +CREG: 1,“0583”,“4044”,0 ← fallback to GSM for unknown reason
18:40:56.054, +QCSQ: “GSM”,-0
18:40:58.429, +CREG: 1,“0071”,“014E952”,7 ← back to LTE mode for unknown reason
18:41:06.368, +QCSQ: “LTE”,91,-120,52,-12 ← operating in LTE again
During this attempt, the initiating side of a call hears the message: “the number you’re calling is unavailable at the moment” as if the LTE module was switched off.
  1. Does this module support VOLTE ? Voice calls in LTE should be handled in this way, as far as I’m concerned.
  2. Why there is absolutely no incomming call notification present when operating in LTE mode?
The firmware version of this module is: EG915UEUABR02A04M08 .
A response to AT+QCFG:
18:38:22.913, AT+QCFG=?
18:38:22.913,
18:38:22.913, +QCFG: “nwscanmode”,(0,1,3),(0,1)
18:38:22.976, +QCFG: “band”,(0-FFFF),(0-7FFFFFFFFFFFFFFF),(0,1)
18:38:23.038, +QCFG: “creg/emergency”,(0,1)
18:38:23.038, +QCFG: “pdp/retrytimes”,(0-10)
18:38:23.103, +QCFG: “airplanecontrol”,(0,1)
18:38:23.103, +QCFG: “qcsq/rssi/negative”,(0,1)
18:38:23.162, +QCFG: “usbnet”,(1,3)
18:38:23.162, +QCFG: “nat/cid”,(0-FFFFFFFF)
18:38:23.226, +QCFG: “urc/ri/smsincoming”,(“off”,“pulse”),(5-2000),(1-5)
18:38:23.287, +QCFG: “urc/ri/other”,(“off”,“pulse”),(5-2000),(1-5)
18:38:23.350, +QCFG: “urc/ri/ring”,(“off”,“pulse”),(5-2000),(1-5)
18:38:23.350, +QCFG: “urc/delay”,(0-120)
18:38:23.415, +QCFG: “urc/cache”,(0,1)
18:38:23.475, +QCFG: “risignaltype”,(“respective”,“physical”)
18:38:23.475, +QCFG: “cmux/urcport”,(0-4)
18:38:23.542, +QCFG: “fota/cid”,(1-7)
18:38:23.542, +QCFG: “fota/times”,(0-120)
18:38:23.542, +QCFG: “fota/path”,
18:38:23.602, +QCFG: “pkalive/ip”,(1-2),<IP_address>,(0-65535)
18:38:23.665, +QCFG: “ledmode”,(0,1)
18:38:23.665, +QCFG: “led/sim”,(0,1)
18:38:23.725, +QCFG: “tone/incoming”,(0,2,3)
18:38:23.725, +QCFG: “ntp”,(1-10),(5-60)
18:38:23.725,
18:38:23.725, OK
Response to QCFG=ims (should turn on VOLTE, according to other posts: Does my EG915U module support VoLTE? ):
18:39:50.037, AT+QCFG=“ims”
18:39:50.037,
18:39:50.100, +CME ERROR: 3
Regards,
Pablo
hi,
The version supports volte. Please use the following command to open volte and test it.
at+qims=?
at+qims=“enable”
thanks
Thank you for a professional response.
The command “AT+QIMS” helped a lot.
Now the module receives +CLIP, +CRING messages during incomming voice call in LTE mode, as it should. This problem seems to be solved.
Is there any newer version of the Firmware for EG915U-EU?
I still see some minor bugs in this Firmware during execution of certain AT commands related to network services.
The firmware version of the purchased modules is: EG915UEUABR02A04M08.
Best Regards,
Pablo
hi,
You’re welcome, please check your email. A new firmware version was sent.
thanks.
Thank you for the new version of the firmware,
Where can I find any manual or application note that explains firmware procedure step by step ?
Best regards!
We also use the EG915U-EU. I realize it might be a long shot, but I’m wondering if there’s an AT command that can automatically configure a SIM card for VoLTE. Currently, to enable VoLTE, we have to manually insert each of the 300 SIM cards we use monthly into a cellphone. This step is necessary before these SIMs can work for calling when placed in the module.
Regards,
Claud
Hi Claud,
Actually I managed to turn on VoLTE in EG915E-EU by this single (but undocumented) AT command:
During tests in 4G, this command solved our problem. The module now shows +CRING, +CLIP notifications during incomming call from LTE network, without any fallback to 2G.
Perhaps some VoLTE initiation was also necessary by ougoing voice call initiation from the module (ATD tel_number;) - but I didn’t confirm it yet. I also didn’t test audio transmission (not used in my application).
Regards,
Pablo
I have the same issue with one of the Turkish cellular company Turkcell.
But another company Türk Telekom sim cards work fine.
I have not tried Vodafone sim cards yet but I will.
Hasan
I’m experiencing the same or a similar issue, and I didn’t want to start a new thread.
The SIM card is from Telekom Hungary. It works fine in a mobile phone — calls can be received normally.
In the EG915U modem:
  • SMS sending works
  • Data connection is functional
  • But there is no RING indication on the UART console when an incoming call is made.
When I call the phone number associated with the SIM card, the modem’s indicator LED switches from blinking to constantly ON, which suggests an incoming call is detected.
However, no RING or +CLIP indications appear on the UART.
Commands I’ve tried:
AT+CLIP=1
AT+CREG=1
AT+QCFG=“nwscanmode”,1,1
AT+QIMS=“enable”
None of these resolved the issue.
Any help would be appreciated.
Finally I have solved. The root cause was that the URC default target is USB AT port not UART1 (Main UART)
So the solution is:
AT+QURCCFG=“urcport”,“uart1”
