I connect the device via USB and I did not have a problem in Windows, but I could not install the Linux driver and connect it to the internet. When I first plugged it in, dev/ttyUSB0, 1, 2, 3 were visible, but after a few kernel operations, it does not appear either. I would be happy if you help.
Please check
dmesg | grep option
Please try
modprobe option
echo 2C7C 6002 > /sys/bus/usb-serial/drivers/option1/new_id
If so you can try the
echo 2C7C 6002 > /sys/bus/usb-serial/drivers/generic/new_id
It seems not like a standard Ubuntu.
OK, now it’s back to normal, the ports are visible, but I’m still not sure if I installed the drivers. I cannot use the internet.
You need to send AT command to set up data call.
AT+QNETDEVCTL=1,1,1
I can connect to the internet. Thank you.
