It is EG25G-GB and if you flash with EG25GGBR07A08M2G_OCPU_30.200.30.200 there should be not a problem.
I thinks it is not the same with Kilishi.
And the modem is stuck in fastboot, is it?
You can provide the uart log.
Good morning,
I would need the latest Quectel USB Driver package for EG25.
I can’t find the zip to download on your site. Many thanks in advance.
I’m in need of EDL mode as well, but I’m confused. On the EC25 hardware design manual it sais that you cannot pull the USB-BOOT pin up before startup, but you suggest doing exactly that. How else are you supposed to use that pin?
I’m confused…
If you need the modem go to EDL mode, you can short the USB_BOOT to 1.8V.
But if you want the modem boot up normally of course you cannot pull up the USB BOOT.
ah I’ve figured out how that works. I needed to suspend twice after bridging the two pins for the modem to firstly appear in EDL mode and to then secondly respond to the flasher hello packets
I’ve got my current status here: Modem stuck in firmware update
Any idea why the flasher keeps hanging indefinitely? ModemManager has definitely been stopped.
