Hi, i have EC25-EUX card. (rev. EC25EUXGAR08A14M1G)
What is the latest firmware version for this card? Can you send me the latest version? If there is.
Hello Herbert, I also have EC25EUXGAR08A14M1G currently use in our modems. Do you have update?
Sometimes, some of the devices are not registering to network, Windows stating āNo serviceā. This happens occassionally in some devices. Maybe the newest firmware could help?
Cheers, Kimmo
Thank you Herbert. So the EC25EUXGAR08A14M1G_20.200.20.200 is the newest one? Then it seems that our current version is already up to date. Cheers, Kimmo
Yes, this is the latest version I can find
Hello, I have two EC25 EUX mini pcie modules. They were working smoothly. However, I can no longer send requests through these two modules. I am getting DNS error. Please find the attached picture.
Current firmware: EC25EUXGAR08A08M1G
Can you send me the latest firmware for these modules?
Thanks.
Can you provide more logs?
Hello Herbert,
I downloaded the latest firmware. However, the problem (Http DNS error - Http no get/post request) still persists.We have 2 EC25EUX mini pcie modules. But both EC25s have the same error.
I got a log record after the firmware update. Below is the log record.
Notes:
Note1: We have EC21 and EG25-G. We can sent request to the same URL as EC21 and EG25-G. There is no problem on the server side.
Note2: Trials were made with different sim cards on EC25s, but the result did not change.
We would be very pleased if you could guide and help us on the subject.
This is the log:
/* Start AT SYNC: Send AT every 500ms, if receive OK, SYNC success, if no OK return after sending AT 10 times, SYNC fail */
[2023-07-07 00:30:13:340_S:] AT
[2023-07-07 00:30:13:395_R:] OK
[2023-07-07 00:30:13:396_S:] ATI
[2023-07-07 00:30:13:451_R:] Quectel
[2023-07-07 00:30:13:451_R:] EC25
[2023-07-07 00:30:13:451_R:] Revision: EC25EUXGAR08A15M1G
[2023-07-07 00:30:13:451_R:] OK
[2023-07-07 00:30:13:462_S:] ATI
[2023-07-07 00:30:13:516_R:] Quectel
[2023-07-07 00:30:13:516_R:] EC25
[2023-07-07 00:30:13:516_R:] Revision: EC25EUXGAR08A15M1G
[2023-07-07 00:30:13:516_R:] OK
/* Use ATV1 to set the response format */
[2023-07-07 00:30:13:517_S:] ATV1
[2023-07-07 00:30:13:573_R:] OK
/* Use ATE1 to enable echo mode */
[2023-07-07 00:30:13:820_S:] ATE1
[2023-07-07 00:30:13:875_R:] OK
/* Use AT+CMEE=2 to enable result code and use verbose values */
[2023-07-07 00:30:14:028_S:] AT+CMEE=2
[2023-07-07 00:30:14:081_R:] AT+CMEE=2
[2023-07-07 00:30:14:081_R:] OK
/* Get the baudrate, if the value is 0 (auto baudrate), then it will be set to 115200 (fixed baudrate) to assure reliable communication and avoid any problems caused by undetermined baudrate between DCE and DTE, value of IPR should be saved with AT&W */
[2023-07-07 00:30:14:333_S:] AT+IPR?
[2023-07-07 00:30:14:387_R:] AT+IPR?
[2023-07-07 00:30:14:387_R:] +IPR: 115200
[2023-07-07 00:30:14:387_R:] OK
/* Use ATI to get module information of Manufacturer ID, Device module and Firmware version */
[2023-07-07 00:30:14:437_S:] ATI
[2023-07-07 00:30:14:492_R:] ATI
[2023-07-07 00:30:14:492_R:] Quectel
[2023-07-07 00:30:14:492_R:] EC25
[2023-07-07 00:30:14:492_R:] Revision: EC25EUXGAR08A15M1G
[2023-07-07 00:30:14:492_R:] OK
/* Use AT+GSN to query the IMEI of module */
[2023-07-07 00:30:14:603_S:] AT+GSN
[2023-07-07 00:30:14:655_R:] AT+GSN
[2023-07-07 00:30:14:655_R:] 865847051004180
[2023-07-07 00:30:14:655_R:] OK
[2023-07-07 00:30:14:657_S:] AT+QURCCFG=āURCPORTā,āusbatā
[2023-07-07 00:30:14:710_R:] AT+QURCCFG=āURCPORTā,āusbatā
[2023-07-07 00:30:14:710_R:] OK
/* Use AT+CPIN? to query the SIM card status : SIM card inserted or not, locked or unlocked */
[2023-07-07 00:30:15:214_S:] AT+CPIN?
[2023-07-07 00:30:15:267_R:] AT+CPIN?
[2023-07-07 00:30:15:267_R:] +CPIN: READY
[2023-07-07 00:30:15:267_R:] OK
/* Use AT+CIMI to query the IMSI of SIM card */
[2023-07-07 00:30:15:372_S:] AT+CIMI
[2023-07-07 00:30:15:425_R:] AT+CIMI
[2023-07-07 00:30:15:425_R:] 286016352364077
[2023-07-07 00:30:15:425_R:] OK
/* Use AT+QCCID to query ICCID number of SIM card */
[2023-07-07 00:30:15:576_S:] AT+QCCID
[2023-07-07 00:30:15:630_R:] AT+QCCID
[2023-07-07 00:30:15:630_R:] +QCCID: 8990011937010307449F
[2023-07-07 00:30:15:630_R:] OK
/* Use AT+CSQ to query current signal quality */
[2023-07-07 00:30:15:681_S:] AT+CSQ
[2023-07-07 00:30:15:733_R:] AT+CSQ
[2023-07-07 00:30:15:733_R:] +CSQ: 24,99
[2023-07-07 00:30:15:733_R:] OK
/* Use AT+CREG? /AT+CGREG? to query the network registration status. */
[2023-07-07 00:30:15:737_S:] AT+CREG?
[2023-07-07 00:30:15:790_R:] AT+CREG?
[2023-07-07 00:30:15:790_R:] +CREG: 0,1
[2023-07-07 00:30:15:790_R:] OK
[2023-07-07 00:30:15:793_S:] AT+CGREG?
[2023-07-07 00:30:15:845_R:] AT+CGREG?
[2023-07-07 00:30:15:845_R:] +CGREG: 0,1
[2023-07-07 00:30:15:845_R:] OK
/* Use AT+COPS? to query current Network Operator */
[2023-07-07 00:30:15:897_S:] AT+COPS?
[2023-07-07 00:30:15:949_R:] AT+COPS?
[2023-07-07 00:30:15:949_R:] +COPS: 0,0,āTurkcellā,7
[2023-07-07 00:30:15:949_R:] OK
/Use AT+CEREG? to query current EPS Network Registration Status/
[2023-07-07 00:30:16:001_S:] AT+CEREG?
[2023-07-07 00:30:16:054_R:] AT+CEREG?
[2023-07-07 00:30:16:054_R:] +CEREG: 0,1
[2023-07-07 00:30:16:054_R:] OK
[2023-07-07 00:30:16:103_S:] AT+CLVL=?
[2023-07-07 00:30:16:155_R:] AT+CLVL=?
[2023-07-07 00:30:16:155_R:] +CLVL: (0-5)
[2023-07-07 00:30:16:155_R:] OK
Can I have the latest firmware please ? My current firmware version is EC25EFAR06A03M4G_SKT_01.003.01.003
. Thanks.
Hi, I got EC25-EFA-512-STD and EX25-EUXGR-128-SGNS, do you have firmware for this?
Hi
My current firmware version is EC25EUXGAR08A09M1G
Thank you
Hello! Could you send the latest firmware for EC25-EC to me?
Hi there,
Can I have the latest firmware for EC25-EUX please ?
Iām current using firmware EC25EFAR06A11M4G
Thank you.
I havenāt received the firmware in my email.
Would you mind check?
I have resent it to your email,pls check
