EC25-EC & EC25-EUX Firmware
Hello, i have several EC25 EC/EUX modules, and having issues with QMI port becoming unresponsive sometimes.
Are there newer firmware versions available?
EC25ECGAR06A08M1G
EC25EUXGAR08A09M1G
Best regards
I have sent them to your email,please check
Received them, thank you very much!
In the EC25-EC release notes it mentions
For Windows,
USB Driver: Quectel_LTE_Windows_USB_Driver_V2.2.4
Qflash Tool: QFlash_V5.9
For Linux,
QFirehose Tool:QFirehose_Linux_Android_V1.4.8
USB Driver: Quectel_LTE&5G_Linux_USB_Driver_V1.0
Could you send me those as well please?
Is it possible to flash the firmware update on Linux or do i have to use Windows?
I also have this model and the problem with lag. Can I have a new firmware please?
Hello! Could you send the latest firmware for EC25-EUX to me?
Could you send me as well - same issues with EC25-EC ! Thank you in advance
Please provide your current firmware version
I need latest firmware for EC25-EUX
EC25EUXGAR08A07M1G_01.001.01.001
EC25ECGAR06A06M1G_01.006.01.006
That’s current firmware i use … can i get newer ones?
Hiya.
I have two modems
EC25EUGAR06A06M4G_01.005.01.005
and
EC25EUXGAR08A05M1G_01.001.01.001
could I have latest firmware for them thanks
Thank you for your support , could you pls. sen me tool and driver for linux/windows to flash modems ?
I have sent them to your email,pls check
Best support ever! thnx
Hi! I have EC25EUXGAR08A07M1G_01.001.01.001. Can I get the newest firmware please?
@herbert.pan-Q, tnx for the firmware. However, the update keeps failing with the following message: “FAIL, DL_Firehose, Time out!”
As you can see on the picture, I am using QFlash v5.8. The USB drivers are “Quectel_LTE&5G_Windows_USB_Driver_V2.1”. OS is Windows 10.
