EC200U with M2M Data SIM AT Commands Flow - PPP Mode
I am trying to establish connection of external MCU with EC200U-CN.
I have got M2M Data sim with me which means I will have to establish ‘PPP’ mode to transfer data instead of normal AT - GPRS commands flow.
Can you please guide me with the M2M sim activation and PPP mode working from start till end so that I can start communicating with the server through MQTT pub sub.
Can you give me your e-mail and i will send you the PPP user guide.
kindly send here: ajit4kavi@gmail.com
Hi i send the ppp user gider to you,pls chk.
HI Iyman-Q, can you share me the PPP user guide with me too? My mail id is - dhari@qmaxsys.com
Hi @Hari
Send to you ,pls chk.
Received Iyman-Q. Thanks
Hi @Athulraj_D_R
Send to you,please check.
I got your mail. Thank you.
Can you please share EC200U PPP user guide. My mail ID is abbisu@tagv.in
Thanks.
Abbisu
Pls send me lasted firmware for EC200U-CNAA.
We have about 30pcs stuck at firmware version A01 - it not support PPP conmection.
My email linhns1991@gmail.com
Thank you!
Hi @Linh_Bui
Send to you,pls chk.
Thank lyman-Q I got firmware
could you share me the script code, my mail id - karthick4it@gmail.com
send me the same please im using m2m sim with ec200u ic please tell me how to configure the
sim with ic
mail id - rishabh@shunyaekai.tech
I am also using M2M sim with EC200U module, can you share the PPP user guide with me too?
My mail is is- aniket.gupta@sindia.co.in
Hello
I have EC200U-EU Module
and try to change mode to PPP but give me +CME ERROR: 53
so please send to me PPP user guide and How activate PPP
Hitham_adel2004@hotmail.com
Hello Iyman-Q,
Can you please share the PPP user guide to design@accordpower.in.
I have already completed HTTP and MQTT connection establishment using a normal SIM, and the implementation is working properly. Now I have moved to an M2M SIM, and while following the same flow, I am not getting the same result.
In detial, HTTP communication is working properly and MQTT connection is getting established successfully. But once I try to publish data, or when any subscribed data is received, the connection is getting closed by the module.
I have already completed domain whitelisting from the M2M provider side as well.
Could you please help me with, the PPP user guide/documentation and Suggestions or checks related to the MQTT disconnection issue with the M2M SIM.
Thanks in advance!
Hi lyman-Q, could you please share the PPP user guide and also the firmware. Trying to establish MQTT with M2M sim with esp32s3 and ec200u
hey @lyman-Q , please share the ppp user guide.
