Module: EC200U-EU-C4-P01
Firmware: EC200UEUAAR03A04M08_OCPU_QPY
uos.uname() reports:
sysname=EC200U-EUAA, release=1.13.0, version=v1.12 on Mon_Jan_13_2025,
qpyver=V0004
Issue: ussl.wrap_socket() hangs until socket timeout during the TLS
handshake to a standard cloud MQTT broker (HiveMQ Cloud, port 8883,
username/password auth, CA-trust only — no client certificate). The
same failure occurs independent of umqtt: I reproduced it directly with
raw usocket + ussl, isolating each layer.
Confirmed working before the handshake:
- LTE registration and PDP context activation
- DNS resolution of the broker hostname
- Raw TCP connect to the broker on port 8883 (succeeds in ~200ms)
Confirmed failing:
- ussl.wrap_socket(sock, server_hostname=host) on that same, already-
connected socket hangs for the full timeout, then raises
OSError: (110,) [ETIMEDOUT] - Same result with server_hostname omitted (SNI not the cause)
- Same result going through umqtt.MQTTClient directly (ssl=True,
ssl_params={}) — not a parameter or config issue - Same result over WSS (uwebsocket.Client.connect to the broker’s
8884 WebSocket-TLS endpoint) — same underlying TLS layer, same hang
This closely matches two other threads on this forum reporting the same
handshake-hangs/fails pattern on EC200U-family modules connecting to
cloud MQTT/IoT brokers over TLS:
- EC200U-CN: SSL Handshake Failure (+QSSLOPEN: 0,579) / QMTOPEN 0,5 on Port 8883 — IoT SIM
- EC200U-CN AWS IoT TLS Handshake Failed - Error 579 / QMTOPEN 0,5 - A13M08
In the second thread, Quectel support provided an updated firmware
build (A13M08 → A17M08) to the reporter. I’d like to request the
equivalent current firmware build for the EC200U-EU-C4-P01 / qpyver
V0004, to test whether it resolves this handshake issue.
Could you confirm:
- Is there a known TLS handshake issue in this firmware’s ussl/mbedTLS
implementation affecting connections to modern cloud brokers? - Is a newer QuecPython firmware build available for this module
variant, and if so, could you provide it?
Happy to share the full isolation test scripts and logs if useful.
