Need to know if there is pre complied kernel or drivers for raspberry pi or ubuntu for EC200U because even after kernel recompilation the modem does not work
There is no need to recompile. See Need Assistance with Quectel EC200U Module Internet Connectivity - #2 by jfrog
I am using Linux raspberrypi 6.1.74-v8+ yet failing to detect modem on system power is visible on the modem cat /sys/kernel/debug/usb/devices
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 1
B: Alloc= 0/800 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0002 Rev= 6.01
S: Manufacturer=Linux 6.1.74-v8+ xhci-hcd
S: Product=xHCI Host Controller
S: SerialNumber=0000:01:00.0
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 4 Ivl=256ms
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 4
D: Ver= 2.10 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=2109 ProdID=3431 Rev= 4.21
S: Product=USB2.0 Hub
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=100mA
E: Ad=81(I) Atr=03(Int.) MxPS= 1 Ivl=256ms
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=5000 MxCh= 4
D: Ver= 3.00 Cls=09(hub ) Sub=00 Prot=03 MxPS= 9 #Cfgs= 1
P: Vendor=1d6b ProdID=0003 Rev= 6.01
Technically you have no modem, it is too early to talk about kernel and drivers.
You need to see a new USB device first. Make sure the modem is properly wired.
the modem is connected using usb cable
S: Manufacturer=Linux 6.1.0-rpi8-rpi-v8 xhci-hcd
T: Bus=01 Lev=02 Prnt=02 Port=02 Cnt=01 Dev#= 3 Spd=12 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=2c7c ProdID=0901 Rev= 3.18
S: Manufacturer=Android
S: Product=Android
C:* #Ifs= 9 Cfg#= 1 Atr=e0 MxPwr=400mA
A: FirstIf#= 0 IfCount= 2 Cls=02(comm.) Sub=06 Prot=00
I:* If#= 0 Alt= 0 #EPs= 1 Cls=02(comm.) Sub=06 Prot=00 Driver=cdc_ether
E: Ad=81(I) Atr=03(Int.) MxPS= 16 Ivl=32ms
I: If#= 1 Alt= 0 #EPs= 0 Cls=0a(data ) Sub=00 Prot=00 Driver=cdc_ether
I:* If#= 1 Alt= 1 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=cdc_ether
E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=84(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=83(I) Atr=03(Int.) MxPS= 64 Ivl=32ms
I:* If#= 3 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=85(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
I:* If#= 4 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=86(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=04(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
I:* If#= 5 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=87(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=05(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
I:* If#= 6 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=88(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=06(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
I:* If#= 7 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=8a(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=07(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=89(I) Atr=03(Int.) MxPS= 64 Ivl=32ms
I:* If#= 8 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=8b(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=08(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
Great, now you can configure the modem as shown in the thread I linked earlier.
But yet no values for GPS or others functions responding
Your AT command port is If#= 2, in your case it should be visible to the OS as /dev/ttyUSB0.
I suggest you create a separate topic on your GPS issues (if any).
No AT commands working
What application do you use to access the port?
Minicom screen do not connect yetModemMana 717 root 13u CHR 188,4 0t0 713 /dev/ttyUSB4
ModemMana 717 root 14u CHR 188,1 0t0 710 /dev/ttyUSB1
ModemMana 717 797 gmain root 13u CHR 188,4 0t0 713 /dev/ttyUSB4
ModemMana 717 797 gmain root 14u CHR 188,1 0t0 710 /dev/ttyUSB1
ModemMana 717 799 gdbus root 13u CHR 188,4 0t0 713 /dev/ttyUSB4
ModemMana 717 799 gdbus root 14u CHR 188,1 0t0 710 /dev/ttyUSB1
Send AT command to check module status
ser.write(b’AT\r\n’)
No response
Remove ModemManager.
