EC200A-EU latest firmware
I have sent the latest firmware to you, please check, and I hope you can click the :yellow_heart: for me,thanks
I have sent it to you, please check, and I hope you can click the :yellow_heart: for me,thanks
Hi @herbert.pan-Q, I have Quectel EC200CN module and have build merge.pac file using CSDK. Could you please guide me how to flash firmware to the module i’m using linux and can you please share me QDloader for linux
Hi @herbert.pan-Q, Thank you for sharing the flashing tool, Currently i’m facing an issue using QDloader
sudo ./QDloader -f APPIMAGE_merge.pac
[000:000] Version: QDloader_Linux_Android_V1.0.11
[000:000] mcu is little endian
[000:000] scan quectel modem
/sys/bus/usb/devices/1-3 2c7c/901/318
open(/dev/bus/usb/001/050) = 4
bluk out = -1, errno: 110 (Connection timed out)
[009:061] AT > AT+QDownLOAD=1
[012:069] scan quectel modem
[021:093] AT > AT+QDownLOAD=1
[024:101] scan quectel modem
[033:125] AT > AT+QDownLOAD=1
[036:133] scan quectel modem
^C
Hi there,
I flashed EC200AEUHAR01A25M16_01.200.01.200 firmware
however, after flashed the firmware I sent “ATZ0” command hoping it would factory reset the module, but after that, I couldn’t open the COM port. I can see the AT port / DIAG port and / ECM but I couldn’t connect to the modem,
Can you please help me to recover my module back to function ?
Just a small update
I was able to open it using PUTTY surprisingly, but the QCOM failed to open, any ideas?
OK, I downgraded my firmware to EC200AEUHAR01A23M16_01.200.01.200 and I was able to connect with QCOM now, but it is not registering my SIM CARD now.
AT+CPIN? - always return CME 10 error ( sim not inserted ) I am not sure what I did wrong. That SIM was working on my phone without any issues, also I tried with two other SIM with different telecom, all ends with same CME 10 error.
Please check whether the SIM PIN is normal
I can assure that the SIM is not locked and doesn’t require any PIN to work
Hi! I have vesion:
EC200AEUHAR01A21M16_01.200.01.200
Can you please send to me firmware and update tool? thanks
Hello @herbert.pan-Q, could you please send me the links to the latest firmware available for the EC200A-AU? Thank you in advance.
@herbert.pan-Q please send me latest firmware for EC200A-EU module, please!
Hi @herbert.pan-Q can you send my latest firmware for EC200A-UE and QFirehose tool? Thx!
I have sent them to you, please check, and I hope you can click the :yellow_heart: for me,thanks
I am using EC200A-CN,
can you please share the latest firmware for the Same to mails2bisu@gmail.com
I am unable to use JIO sim in India with this.
when you use JIO carrier and SIM card,you should configure
AT+CFUN=0
AT+CGDCONT=1,“ipv6”,“jionet”
AT+CFUN=1
AT+QENG=“servingcell”
AT+QIACT=1
AT+CGPADDR
