EC200 firmware file and how to update it
I am working on EC200 project and I want to upgrade my EC200 firmware, how do I do it, where to get latest firmware from
my current firmware version is
VERSION : EC200UCNAAR02A09M08
hi ,
Please provide your email address, I will send you the latest firmware version thanks.
amogh.sadhu@varostechnology.com
It has been sent by email.
Hi AnnaLiu,
My module has this version: EC200UCNAAR02A10M08. Can you send the latest version?
And I have the EC200U-CN UMTS&LTE EVB KIT but I don’t know how to program on it. Please give me documets guide such as SDK example code with make file.
Email:prakashmercyda23@gmail.com
Thanks,
You can check the email for the firmware. The documentation on how to program the evb board is useless to me, I’m sorry.
hello support
i am using Quectel EC200U-EU (EC200UEUAA-N05-SGNSA) and Revision: EC200UEUAAR02A06M08.
after entering to CMUX mode, Quectel module dosen’t respond to long length messages that is sent to it.
i think if i upgrade the firmware it’ll be solved. can you send me last firmware and tools please? javidtaherisrc@gmail.com
Hello, do you need the firmware version?
Hello team
I am trying to update the firmware of EC200 firmware.. I tried one available in the open public domain but its throwing “No Key error..” when used with Qflash v4.9.
Could you please send me the latest firmware and Qflash for the below version?
EC200UCNAC-N05-SNNSA
Email : lanradios@gmail.com
Siddharth
Lanradios Networks
hi,
Please check the private message, thank you, it has been sent to you.
Hi AnnaLiu,
I am working on EC200U-CN module. Now i am facing one issue with the AT+CLIP command . After set the AT+CLIP = 1 command , i am getting the caller line identification number (caller mobile number) at the first time after the RING indication happend. In the remaining RING indication I did not get the caller Identification number.
Please suggest a solution. I think this is due to the firmware problem.
The current firmware version of the module is - EC200UCNAAR02A09M08.
If you have the latest version firmware please send to me. i will try to chage the firmware and check it.
hi ,
I tested the new version locally and there was no problem. Please check the email.
[2024-01-08_11:19:00:355]EC200UCNAAR03A08M08
[2024-01-08_11:19:00:355]OK
[2024-01-08_11:19:30:282]AT+clip=?
[2024-01-08_11:19:30:282]+CME ERROR: 53
[2024-01-08_11:19:35:611]AT+clip=?
[2024-01-08_11:19:35:611]+CLIP: (0,1)
[2024-01-08_11:19:35:611]OK
[2024-01-08_13:26:07:052]AT+clip=1
[2024-01-08_13:26:07:052]OK
[2024-01-08_13:26:58:506]atd15072713431
[2024-01-08_13:26:58:563]OK
[2024-01-08_13:27:30:391]
[2024-01-08_13:27:30:391]NO CARRIER
[2024-01-08_13:27:31:774]ath
[2024-01-08_13:27:31:774]OK
[2024-01-08_13:27:37:703]
[2024-01-08_13:27:37:703]RING
[2024-01-08_13:27:37:703]+CLIP: “15072713431”,129,0,0
[2024-01-08_13:27:42:706]
[2024-01-08_13:27:42:706]RING
[2024-01-08_13:27:42:706]+CLIP: “15072713431”,129,0,0
[2024-01-08_13:27:47:708]
[2024-01-08_13:27:47:708]RING
[2024-01-08_13:27:47:713]
[2024-01-08_13:27:47:713]+CLIP: “15072713431”,129,0,0
[2024-01-08_13:27:52:707]
[2024-01-08_13:27:52:707]RING
[2024-01-08_13:27:52:707]+CLIP: “15072713431”,129,0,0
thanks
i also needed the firmware could you send me the same
hi,
Please check your emails.
hi ,
i need an updated firmware version of ec200
my current firmware version is EC200UCNLAR02A07M08_OCPU
my email is rushikesh.deshpande@iogenies.com
hi , I am using the version EC200UEUAAR03A05M08 and I have the problem of searching the network. +CREG result: 0,0 - Do I need to update the firmware?
Musavypoor@gmail.com
hi,
AT+CREG?To check the CS domain network registration status, first make sure there are 2G and 3G networks. You can use AT+QENG=“servingcell” to check the network status.
We analyzed with QNavigator software - I am attaching its documentation. Some of the modules work properly, some of them have this problem
Are the normal module and abnormal module the same version? You can check whether the antenna is connected properly.
