EC200 firmware file and how to update it
normal module version is : EC200UEUAAR03A02M08
abnormal :EC200UEUAAR03A05M08
main board is same, we have checked anything about hardware
Please see the email below. I have sent you the latest firmware version. You can upgrade and test it.
I’m working on ec200aella-n06-snasa
can i get latest firmware?
Hello, can I also get the ec200 hmi updated os from you? My email is oscar0918058634@gmail.com
Thank you very much
I wonder why you keep the firmware as a secret? What it is not available publicly and we should send our email here to get it? So strange!
Can you send me the latest firmware for ec200u?
my email: yugen.maharjan@nepaldigisys.com
send me latest firmware I’m using EC200UCNAAR03A09M08 my mail logitechbhilai@gmail.com
@Logitech_Bhilai
Hi, i will check and send that if i get the latest firmware. Much appreciation.
my firmware version is EC200UEUAAR03A17M08 , pls give me new firmware file to ru.suttisak@flexiasolutions.com
Hola, alguien tendra el firmware standar para el EC200U-AU, se agradecería si nos pueden enviar a mi email, gracias: siracomchile@gmail.com
Hello Quectel Support,
I am working with a Quectel EC200U-AU module and I need to use voice calls (VoLTE) together with SMS for a remote monitoring application.
The current firmware installed in the module is:
EC200UAUAAR03A01M08_OCPU_QPY
The module works correctly for LTE registration and SMS, but voice calls do not work.
Tests performed:
AT+CPIN? → +CPIN: READY
AT+CREG? → +CREG: 0,1
AT+CEREG? → +CEREG: 0,1
AT+COPS? → +COPS: 0,0,"ENTEL PCS",7
AT+CSQ → +CSQ: 23,99
AT+CLCC → OK
When trying to make a voice call:
ATD+569XXXXXXXX;
the module returns:
+CME ERROR: 53
Incoming calls are also not detected. There is no RING indication, and AT+CLCC returns only OK while an incoming call is being attempted.
The same SIM card works correctly for both voice calls and SMS when installed in a mobile phone.
I also tested GSM-only mode using:
AT+QCFG="nwscanmode",1
but the module could not register on the GSM network. In automatic mode (nwscanmode=0) it registers correctly on the Entel Chile LTE network.
I found information in this forum about EC200U QuecPython firmware versions with VoLTE support, including firmware names containing VOBT_OCPU_QPY.
Could you please provide or indicate the correct VoLTE-enabled OCPU/QuecPython firmware specifically for EC200U-AU?
I do not want to flash firmware intended for EC200U-CN/EU or another hardware variant.
My requirement is:
EC200U-AU + QuecPython/OCPU + SMS + VoLTE voice calls.
If a firmware update is required, please also provide the appropriate flashing tool/instructions for this EC200U-AU version.
Thank you for your assistance.
