Does anyone have published data on Azure cloud in IoT hub using AT commands?
Hello Everyone,
I have tried with EC200U, from series MQTT application Note example of MQTT operation without SSL where I have given AT commands
AT+QMTOPEN=0,“”,8883
ok
+QMTOPEN: 0,0
AT+QMTCONN=0,“ec200”,“YM_DEVICE_01”,“Password@123”
+QMTCONN: 0,1
most of time I got error
+QMTCONN: 0,1
+QMTSTAT: 0,1
Please reply to this if anyone has solved this error or published data on Azure IoT hub using EC200cn-u AT commands.
Dear customer,
Per your log, it looks like server close the connection. If the client there is no actions in specified periods. Server may close the connection to save resource. There is no timestamp in your log. Please check if your aplication is working in this situation. If yes, you need re-connect server.
16:44:07.777 -> AT+QMTOPEN=0,"<URL>",8883
16:44:07.777 -> OK
16:44:10.246 ->
16:44:10.246 -> +QMTOPEN: 0,0
16:44:12.523 -> AT+QMTCONN=0,"Test","<USERNAME>","<PASSWORD>"
16:44:12.555 -> OK
16:44:12.910 ->
16:44:12.910 -> +QMTCONN: 0,1
16:44:12.910 ->
16:44:12.910 -> +QMTSTAT: 0,1
16:45:57.355 -> AT+QMTOPEN=0,"<URL>",8883
16:45:57.355 -> OK
16:45:57.875 ->
16:45:57.875 -> +QMTOPEN: 0,0
16:46:01.585 -> AT+QMTCONN=0,"Test","<USERNAME>","<PASSWORD>"
16:46:01.619 -> OK
16:46:01.945 ->
16:46:01.945 -> +QMTCONN: 0,1
16:46:01.945 ->
16:46:01.945 -> +QMTSTAT: 0,1
My concern is it my flow is right to publish data on Azure cloud?
As I am not executing the AT+QMTCFG=" “,0,” “,” “,” " AT command mentioned in example for without SSL, but is this compulsory to execute this command then, how should I run it for Azure cloud?
Although I have executed following commands
AT+QMTCFG="keepalive",0,120
AT+QMTCFG="version",0,4
AT+QMTCFG="session",0,1
AT+QMTCFG="timeout",0,5,10,1
AT+QMTCFG="will",0,0,0,0,"",""
+QMTOPEN: 0,0
+QMTCONN: 0,1
+QMTSTAT: 0,1
@rodney.wang suggest me the flow of AT commands to publish data on azure IoT hub.
Thanks.
cool.
Is this type of platform specific application manual available for Azure cloud platform?
I have credits of azure cloud, and I want to utilize it.
Thanks.
[Sharing] Microsoft Azure Guide.pdf (1.2 MB)
