Here are the outputs,
Hi, I can understand that your script is for the host computer to realize data dialing through USB?
The script just runs minicom on ttyUSB2. It’s so I don’t have to keep typing the whole command everytime.
And yes I am trying to use RNDIS mode
Generally speaking, you can check whether there is a problem with the corresponding driver. In addition you can refer to AT+qcfg=“usbnet” Query the current network card mode of the module. Configurable
I can successfully share my phone data with RNDIS. Also the query shows 3, which I believe is the RNDIS mode?
I have tried connecting the board to windows as well. It has no data throughput there either.
