DCHP with RM520N-GL (ethernet mode?)
Hi, I’m using an RM520N-GL in a M2 adaptor. It’s running in an ethernet mode, with RJ45 output. The connected computer gets an IPv4 address in the range 192.168.225.x. What I would like to know is how to change that range (eg to 192.168.10.x). Is there a command reference covering this please?
Also, can the module supply a DCHPv6 IP address?
Thanks!
You can obtain the address assigned by the carrier and avoid extra NAT, see Can't place RM520 in IP Passthrough (IPPT) mode - #4 by sirozha
See this for IPv6: RM520N-GL IP Passthrough with Network Adatper Mode
Thanks, that is very useful.
But can you also advise me on how to manage the DCHP server please?
Cheers!
Same thread, first message:
Command syntax is shown in the other thread I linked:
+QMAP: "LANIP",<LAN_IP_start_address>,<LAN_IP_end_address>,<GW_IP_address>
