Greetings
Can someone please help me change the gateway of the RM520N module
to make it work with an IP range of /30 for example…
Greetings
Can you give more context?
My scenario is very similar to this one, only the module and mikrotik model changes…
Cannot you switch from ECM to MBIM?
If for whatever reason you want to stay with the current mode, see EG18EA change local ip in ECM mode
before there was a range /24, these are currently coming from a range /22, I wanted to reduce this range and change the gateway
See if you can use AT+QCFG="gatewayset" and AT+QCFG="netmaskset"
thank you very much
you saved me…
