CC660D-LS Linux drivers
I have the CC660D-LS module but it is not detected on my linux system.
Please provide the linux drivers for module CC660D-LS.
Thanks!
If it is connected over USB start from checking with
cat /sys/kernel/debug/usb/devices
It is connected by USB but, there is not in cat /sys/kernel/debug/usb/devices, I suppose because I need the drivers to make it work.
Not related to drivers. If the output is completely empty, try using another Linux machine if available.
Find below the output for cat /sys/kernel/debug/usb/devices command
T:  Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=480  MxCh= 1
B:  Alloc= 36/800 us ( 5%), #Int= 25, #Iso=  0
D:  Ver= 2.00 Cls=09(hub  ) Sub=00 Prot=01 MxPS=64 #Cfgs=  1
P:  Vendor=1d6b ProdID=0002 Rev= 5.04
S:  Manufacturer=Linux 5.4.0-1122-raspi dwc2_hsotg
S:  Product=DWC OTG Controller
S:  SerialNumber=3f980000.usb
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=  0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub  ) Sub=00 Prot=00 Driver=hub
E:  Ad=81(I) Atr=03(Int.) MxPS=   4 Ivl=256ms
T:  Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#=  2 Spd=480  MxCh= 5
D:  Ver= 2.00 Cls=09(hub  ) Sub=00 Prot=02 MxPS=64 #Cfgs=  1
P:  Vendor=0424 ProdID=9514 Rev= 2.00
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=  2mA
I:  If#= 0 Alt= 0 #EPs= 1 Cls=09(hub  ) Sub=00 Prot=01 Driver=hub
E:  Ad=81(I) Atr=03(Int.) MxPS=   1 Ivl=256ms
I:* If#= 0 Alt= 1 #EPs= 1 Cls=09(hub  ) Sub=00 Prot=02 Driver=hub
T:  Bus=01 Lev=02 Prnt=02 Port=00 Cnt=01 Dev#=  3 Spd=480  MxCh= 0
D:  Ver= 2.00 Cls=ff(vend.) Sub=00 Prot=01 MxPS=64 #Cfgs=  1
P:  Vendor=0424 ProdID=ec00 Rev= 2.00
I:* If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=ff Driver=smsc95xx
E:  Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=83(I) Atr=03(Int.) MxPS=  16 Ivl=1ms
T:  Bus=01 Lev=02 Prnt=02 Port=02 Cnt=02 Dev#=  4 Spd=12   MxCh= 0
D:  Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
P:  Vendor=067b ProdID=2303 Rev= 3.00
S:  Manufacturer=Prolific Technology Inc.
S:  Product=USB-Serial Controller
C:* #Ifs= 1 Cfg#= 1 Atr=a0 MxPwr=100mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=pl2303
E:  Ad=81(I) Atr=03(Int.) MxPS=  10 Ivl=1ms
E:  Ad=02(O) Atr=02(Bulk) MxPS=  64 Ivl=0ms
E:  Ad=83(I) Atr=02(Bulk) MxPS=  64 Ivl=0ms
T:  Bus=01 Lev=02 Prnt=02 Port=03 Cnt=03 Dev#= 12 Spd=12   MxCh= 0
D:  Ver= 1.10 Cls=ff(vend.) Sub=00 Prot=00 MxPS= 8 #Cfgs=  1
P:  Vendor=1a86 ProdID=7523 Rev= 2.63
S:  Product=USB2.0-Serial
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr= 98mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=01 Prot=02 Driver=ch341
E:  Ad=82(I) Atr=02(Bulk) MxPS=  32 Ivl=0ms
E:  Ad=02(O) Atr=02(Bulk) MxPS=  32 Ivl=0ms
E:  Ad=81(I) Atr=03(Int.) MxPS=   8 Ivl=1ms
T:  Bus=01 Lev=02 Prnt=02 Port=04 Cnt=04 Dev#= 13 Spd=480  MxCh= 0
D:  Ver= 2.00 Cls=ff(vend.) Sub=80 Prot=37 MxPS=64 #Cfgs=  1
P:  Vendor=1a86 ProdID=e018 Rev=37.01
S:  Manufacturer=wch.cn
S:  Product=USB2.0 To Multi Serial Ports
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=100mA
I:* If#= 0 Alt= 0 #EPs= 4 Cls=ff(vend.) Sub=80 Prot=37 Driver=(none)
E:  Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
You must assume there is another Quectel (BC95G) connected.
From previous output I can’t know if Quectel CC660D-LS is recognized or connected or not.
Technically your module cannot be connected to the host over USB. You have USB connection with some evaluation board and not with the module directly.
Your computer is connected over USB to CH9344 USB-to-serial converter that resides on the EVB along with the module. This converter chip is connected to the module over serial lines or UART.
Drivers for the converter are available in CC660D-LS support
