CC660D-LS support
Hello Madam/Sir,
I recently bought CC660D-LS modem for satellite comms… Problem I face is I do not have WIN USB drivers for it nor can find it anywhere.
As well is there anywhere AT commands manual for setting the modem up? I do have satellite provider SIM card, and could you please help me out to proceed there?
Thank you and best regards
/t
hi @tm38691
Please check attached AT commands manual
[Quectel_CC660D-LS_AT_Commands_Manual_V1.0.0_Preliminary_20230525.pdf|attachment]
Drivers for windows :
CH9344L驱动(2).7z (489.8 KB)
thx a lot Waleed! really appreciated!
installed provided software but modem still not recognized
have modem on the CC660DLSAA-I03-TB0AA… At the moment stuck for quite some time with testing. Please need help there:
Best regards
Tomislav
hi @tm38691
May I ask if you are working with our Evaluation Board or with the module only ?
Need to confirm which interface are you connecting to.
Hello
is evalboard CC660DLSAA-I03-TB0AA
Tomislav
Dear @Waleed_Zafar1 ,
Can you also share the Linux driver for the CC660D-LS eval board or share with us how to set up serial communications in Linux/Ubuntu to talk to the chip with AT commands?
Many thanks,
Best Regards
Aygün
hi @ayguen_b
Please check the drivers for Linux
CH9344SER_LINUX.ZIP (22.1 KB)
Dear @Waleed_Zafar1,
Thank you very much for sharing the Linux drivers!
I could successfully compile the drivers and got to talk to the NTN chip with AT commands. However, so far I observed that the serial comms is not always stable – the modem stops responding to my AT commands after a while. Are there also CDC drivers for the CC660 board and can you share them with us? Hoping that CDC drivers could help establish more stable communications. If you also have any suggestions to make the serial communications reliable, please let me know.
Many thanks,
Best Regards
Aygün
hi @ayguen_b
can you please tell what is “CDC” ?
Hi @Waleed_Zafar1 ,
“Communications Device Class” → CDC: With CDC drivers, the OS would recognize the CC660D-LS board as a modem so and I could directly communicate with the board using conventient modem manager tools (e.g., mmcli) rather than unstable AT commands. I hope that such CDC driver is available for the board otherwise please let me know how to achieve stable communications over AT commands since the serial communication keeps breaking up after some time.
Thanks in advance,
Best Regards
Aygün
Hi @Waleed_Zafar1 ,
Just a reminder that I am still looking for a driver to have my CC660D-LS device recognized as a modem on Ubuntu/Linux. As far as I read on the internet, there are some Quectel-CM or qmi-wwan drivers to attach the CC660 as a network device on my PC, so I look forward to your support to send me whatever driver is necessary to use the device as a network device. Many thanks!
Best Regards
Aygün
We are working with the Quectel CC660D-LS module and are trying to use Non-IP / NIDD-style communication over NTN.
We are able to configure and activate the Non-IP context successfully using commands like:
  • AT+QCGDEFCONT="Non-IP","<APN>"
  • AT+QGACT=1,4,"<APN>","","",1,1
We also see successful activation response such as:
  • +QGACT: 1
  • OK
  • +QGACT: 1,1,1,4
For uplink, we understand that AT+CSODCP is used for sending control-plane data.
However, we are unable to find a clear AT command or URC for receiving downlink Non-IP / NIDD data on the CC660D-LS.
Our questions are:
  1. What is the correct AT command or URC to receive downlink Non-IP / NIDD data on CC660D-LS?
  2. Is there any command equivalent to +CRTDCP or any proprietary Quectel command for downlink control-plane data reception on this module?
  3. If downlink reception is URC-based, what URC should we expect?
  4. Is any additional configuration required to enable downlink Non-IP data reception?
We would appreciate it if anyone could share the exact AT command sequence for both uplink and downlink Non-IP communication on CC660D-LS.
Thank you.
