Hi, i am getting error while trying to send a USSD message using AT command.
AT+CMEE=2
AT+CSCS=“GSM”
AT+CUSD=1,“*276#”,15
ERROR
Note: The device is properly registered to the network (GSM)
Note: I am using the BG96 on a “UMTS & LTE EVB Kit” and I am getting an
The AT command reference of the BG96 states that:
If there is any other error, response:
ERROR
Did any one of you ever manged to send a USSD from the BG96 ?
Any idea on How i can get more info on the “ERROR” reason ?
Regards
Oren
Hi Oren ,
For BG96 module , it does not support USSD function .
so sorry , thanks
Thank you very much, Stephen.
Do you know if there are any plans to support ussd in the future ? (it is a key feature in my app)
Dear Oren,
Please read chapter 10.8 of the included Quectel_BG96_AT_Commands_Manual_V2.3.pdf
Quectel_BG96_AT_Commands_Manual_V2.3.pdf (1.5 MB)
Good luck ;o)
Thank you very much Leonardus,
I saw the AT+CUSD command and still failed to execute it.
It seems like the BG96 doesn’t support this command ..
According to Stephen the BG96 doesn’t support AT+CUSD command.
Regards
Oren
Dear Oren, After asking with R&D, indeed BG96 can not support USSD.
The command AT+CUSD will be removed from the AT manual.
The reason is that USSD uses 2G CS (Circuit Switched),but the BG96 has no CS domain, only PS (Packet Switch) domain.
I want to know Data validity of Quectel modem(BG96) but above one said it doesnt support.
is there any alternative to know the data balance or vality ?
if anyone knows please help me.
its really important to my project.
Best regards,
M.MOUNIKA
