So, moving forward got to data sending from device and got stuck.
I used example from BG96MAR04A03M1G_02.003.01.003 , tcp_client. It starts well, initializes DDS, sent APN and receive IP. But on connection it fails. No matter what server I put to DEF_SRV_ADDR and port to DEF_SRV_PORT. Here is log dropped to debug uart. (Btw, tried to get errno function and it returns 2 regardless I tried to connect existing or not existing server).
Any ideas ?
[2019-12-16_20:53:14:297] TCPClient Task Start…
[2019-12-16_20:53:25:456]Initializes the DSS netctrl library
[2019-12-16_20:53:25:472]DSS netctrl library has been initialized.
[2019-12-16_20:53:25:502]Registering Callback tcp_dss_handle
[2019-12-16_20:53:25:502]tcp_dss_handle -177785049, status 0
[2019-12-16_20:53:25:502]Registed tcp_dss_handler success
[2019-12-16_20:53:25:518]Setting tech to Automatic
[2019-12-16_20:53:25:518]Setting APN - CMNET
[2019-12-16_20:53:25:534]Setting family to IPv4
[2019-12-16_20:53:25:550]qapi_DSS_Start_Data_Call start!!!.
[2019-12-16_20:53:25:566]Start Data service success.
[2019-12-16_20:53:28:907]Data test event callback, event: 1
[2019-12-16_20:53:28:923]Data Call Connected.
[2019-12-16_20:53:28:951]<— static IP address information —>
[2019-12-16_20:53:28:951]static IP: 10.141.131.65
[2019-12-16_20:53:28:951]Gateway IP: 10.141.131.66
[2019-12-16_20:53:28:967]Primary DNS IP: 81.95.167.65
[2019-12-16_20:53:28:967]Second DNS IP: 81.95.167.66
[2019-12-16_20:53:28:983]<— End of system info —>
[2019-12-16_20:53:28:999]SIGNAL EVENT IS [4]
[2019-12-16_20:53:28:999]DSS_SIG_EVT_CONN_E Signal
[2019-12-16_20:53:29:015]<-- Create socket[16385] success -->
[2019-12-16_20:53:29:031]Connect to servert error
