I’m working on a bg96 sending data to and from an UDP server.
the issue i m encoutring is that the bg96 randomly intiate reselection procedure that can take up to 6min to reconnect to the network.although there is only one available cell.
it seems that the issue isnt related to the signal quality indicator(RSRP,RSSI,RSRQ) since the module is immobile and the signal quality seems to be stable.
i m using at+qeng=“servingcell” to check if it is camping on a cell.
I tried configuring it using:
at+QCFG=“band”,00000000,00000000,80000
AT+QCFG=“nwscanseq”,030201
AT+QCFG=“nb1/bandprior”,14
that reduced the reconnection periode to ~100sec but it is still happening in a random fashion.
i also noticed that the command at+qcops=4,1 sometime show no availabe networks.
the powering off and then on make the module reconnect normally to the network in <10sec
what is the issue?
