Hello. When I plug the GSM
module to PC USB port, QFlash app shows three different ports. Named respectively 3,4,5. Why? I need to upgrade firmware with QFlash. I have QFlash.
My second problem related to update is
.mbn files. This is a part of Quectel_QFlash_User_Guide pdf to upgrade firmware. I have new firmware version-BG95M3LAR04A03_01.201.01.201. I don’t have the first and the second .mbn files in the
update folder.
Please help me
Thank you for instant reply. The second answer was not clear to me. Because In the picture, I see BGxx after ECxx.
please share a screen shot
The red pattern that I underlined
This is ECxx firmware, its different with BGxx, becasue they are not same platform
BGxx series in update folder should be like this:
Thank you, I got you. So, do I have to choose the whole update folder?
You just need enter firehose folder and select the partition.mbn file, then it will load all files to QFLASH, no need do any other.
Hello, we have such an error. We did VDD_EXT & BOOT pins
In the first picture, we selected com port 12. While upgrading process, it’s automatically created this port at the following picture.
The DM port will be auto change as QDLoader port, this is no problem.
But for the error, have you changed firmware packet name as Quectel_BG95M3_Firmware_Releasexxx?
please do not change fw name.
Thank you for an instant reply.
No we have not changed anything.
The version of QFlash is 6.3
what’s this ? can you share the fw path here?
You say that BG95 C:\Users\kerim\OneDrive\Desktop\BG95-m3\Quectel_BG95M3_Firmware_Release is wrong path? especially Quectel_BG95M3_Firmware_Release? Because update folder is inside Quectel_BG95M3_Firmware_Release folder
Yes I’ve created the named Quectel_BG95M3_Firmware_Release folder and extract all files inside it. I have BG95M3LAR04A03_01.201.01.201.zip and I make an extract all files of the folder to Quectel_BG95M3_Firmware_Release folder that i’ve made
yes, please try without no change fw floder name, just like this:
E:\xxxx\BG95M3LAR02A03_01.006.01.006\update\firehose
And the file path you shown seems too long.
