I’m using a Dragino BC95-G shield with Arduino Uno. I’m trying to connect with a server over UDP using IP address and port number. See below for the code I am using from Dragino github page. The problem I am experiencing is that the Serial output from the BC95 is scrambled/illegible, and the CEREG state is stuck at 0,5 (the “5” meaning that the device is roaming and not connected to the home network).
Does anyone know what is going on? Many thanks!
#include <SoftwareSerial.h>
const int timer = 15000; //timer, default: six minites;
/****define Serial port*****/
const byte rxpin = 10; //Software Serial port
const byte txpin = 11;
const int port = PORT NUMBER; //server port
const char udpserver[] = "THE SERVER IP ADDRESS";
static char retmcu[256] = {'\0'}; //save the mcu return message for AT Command
static byte reboot = 0;
static char IMEI[16] = {'\0'};
#define MAXLEN 256 // MAX Payload length
#define CHARLEN 32
#define BAUDRATE 9600 //define the baud is 9600bps/s
void mcu_init(); //CPU
int mcu_at_nmgs(int, char *);
void send_data_udp(int, char *);
void read_downstream();
char *mcu_get_imei(char *);
SoftwareSerial bc95_serial(rxpin, txpin); // RX TX, initialise instance of Arduino "SoftwareSerial" object.
* funciton name :setup()
* parameter :NONE
* return value :NONE
* effect :initialize Arduino's function of setu
* data :2018/4/16
void setup() { //set the data rate for the Serial port
Serial.begin(BAUDRATE); // Use Serial Port for debug(config the baud of uart is 9600bps/s)
bc95_serial.begin(BAUDRATE); //config module of bc95 baud of uart is 9600bps/s too.
Serial.println("Start of setup ----------------");
mcu_init(); //module were initialized.
delay(1000); //Arduino delay 1 second
Serial.println("End of setup ------------------");
* funciton name :loop()
* parameter :NONE
* effect :NB-IoT init and send for data to platform
* data :2018/4/16
void loop() {
send_UDP_message();
// bc95_PSM_setting();
// bc95_eDRX_setting();
/* Generate Power Saving Mode Status Report - Read only */
void bc95_PSM_report(void){
Serial.println(F("AT+NPSMR?"));
bc95_serial.println(F("AT+NPSMR?"));
bc95_serial_read();
/* Enable the power save mode (PSM) setting - PSM can only be activated by network */
void bc95_PSM_setting(void){
// Requested periodic Tau: bits 1-5 = binary coded timer value
Serial.println(F("AT+CPSMS=1,,,00100100,00001000")); /* First parameter is enable/disable PSM, second param is requested periodic Tau, third param is requested active time */
bc95_serial.println(F("AT+CPSMS=1,,,00100100,00001000"));
bc95_serial_read();
void bc95_eDRX_setting(void){
Serial.println(F("AT+CEDRXS=1,5,0101"));
bc95_serial.println(F("AT+CEDRXS=1,5,0101"));
void send_UDP_message(){
//Serial.println(F("Send a message use UDP Protocol")); //computer will printed to char string
bc95_serial_clearbuf();
bc95_serial.println(F("AT+NSOST=0,SERVER IP ADDRESS,PORT,3,616263")); // Send message via UDP. ARGS: socket, remote IP, remote port, payload size, payload.
Serial.println(F("AT+NSOST=0,SERVER IP ADDRESS,PORT,3,616263"));
//bc95_serial_clearbuf();
delay(565);
Serial.println("receive:");
bc95_serial.println(F("AT+NSORF=0,3"));
bc95_serial_read();
delay(2000);
* funciton name :bc95_serial_read()
* parameter :NONE
* effect :data was straged in retmcu array
* data :2018/4/16
void bc95_serial_read()
int i = 0;
memset(retmcu, 0, sizeof(retmcu));//reference c language lib menset
//array is cleaned in here
bc95_serial.flush(); //Waits for the transmission of outgoing serial data to complete.
delay(1500); //Waits for respones from server
while(bc95_serial.available() && i < sizeof(retmcu) - 1) {
retmcu[i] = bc95_serial.read();//read return's value and strage in this array
i++;
retmcu[i] = '\0'; //
Serial.println(retmcu); //for debug
* funciton name :bc95_serial_clearbuf()
* parameter :NONE
* effect :clear the buffer
* data :2018/4/16
void bc95_serial_clearbuf()
while(bc95_serial.available()) {
bc95_serial.read();
* funciton name :str2hex()
* parameter :NONE
* effect :conver strings to ascii code
* data :2018/4/16
void str2hex(char *hexstr, int hexlen, char *str, int strlen)
int i;
char tmp1[4] = {'\0'};
for (i = 0; i < strlen - 1; i++) {
sprintf(tmp1, "%x", str[i]);
strncat(hexstr, tmp1, hexlen);
* funciton name :mcu_at_nrb()
* parameter :NONE
* effect :Reboot BC95
* data :2018/4/16
void mcu_at_nrb()
bc95_serial_clearbuf(); //clear the buffer
Serial.println(F("Reboot BC95")); //
bc95_serial.println(F("AT+NRB")); //send AT+NRB command to NB-IoT,this command is that module will be reboot
* funciton name :mcu_at_ok()
* parameter :NONE
* effect :Sent the AT command
* data :2018/4/16
void mcu_at_ok()
while(1) {
bc95_serial.println(F("AT")); //send "AT"command to NB-IoT
bc95_serial_read(); //read the return value
if (strstr(retmcu, "OK") != NULL) { //if return value is "OK" than program delay 1second jump out loop
delay(1000);
break;
* funciton name :mcu_get_cimi
* parameter :NONE
* effect :Sent the AT+CIMI command (request the International Mobile Subscriber Idendity)
* data :2018/4/16
void mcu_get_cimi()
while(1) {
bc95_serial_clearbuf(); //flush bc95_serial
Serial.println(F("AT+CIMI")); //
bc95_serial.println(F("AT+CIMI")); //send AT+CIMI command to NB-IoT module
break; //jump out of loop
* funciton name :mcu_get_imei
* parameter :*char
* return value :*char
* effect :gain the IMEI code
* data :2018/4/16
char *mcu_get_imei(char *imei)
int i;
char *pt; //this pointer in order to recevied the IMEI code take in imei array
Serial.println(F("AT+CGSN=1")); //
bc95_serial.println(F("AT+CGSN=1")); //send the "AT+CGSN=1"command,then the return value is IMEI code
bc95_serial_read(); //read return code
//judge if have return value of IMEI code
if (strstr(retmcu, "+CGSN") != NULL) { /* respones format: +CGSN:86370303110???? */
pt = strrchr(retmcu, ':'); //
for(i = 0; i < sizeof(IMEI); i++) {
imei[i] = pt[i+1]; //store the IMEI code to imei array.
return imei; //return the imei array
return NULL; //or return NULL
* funciton name :mcu_at_nband()
* parameter :NONE
* effect :Arduino sent"AT +NBAND"to NB-IoT,we choose band 20 since vodafone NL uses that.
* data :2018/4/16
void mcu_at_nband()
while(1) {
bc95_serial_clearbuf(); //clean the buffer to NB-IoT
Serial.println(F("AT+NBAND?")); //Arduino print "AT+NBAND?" char string to computer
bc95_serial.println(F("AT+NBAND?")); //Arduino send "AT+NBAND?"command to NB-IoT,in order to looking the module work in state
if(strstr(retmcu, "+NBAND:20") != NULL) { //Read the retmcu array,Arduino start judge the value appear nbnber"5"
break; //if the value is number"5",NB-IoT working frequency is 850Mhz,jump out of the loop.
} else {
Serial.println(F("AT+NBAND=20")); //if the return value isn't number"5",afterward,Arduino sent "AT+NBABD=5"command to NB-Iot module.
bc95_serial.println(F("AT+NBAND=20")); // AT+NBABD=5 command is chose the mode that NB-IoT working frequency is 850Mhz
reboot = 1; //reboot laber bit assignment is "1".
break; //program jumps out of the loop
* funciton name : mcu_at_cgdcont()
* parameter :NONE
* effect :Define a PDP Context * notice:
* data :2018/4/16
void mcu_at_cgdcont()
// Serial.println(F("AT+CGDCONT=1,IP,CTNB"));
// bc95_serial.println(F("AT+CGDCONT=1,\"IP\",\"CTNB\""));
Serial.println(F("AT+CGDCONT=1,IP,lpwa.vodafone.iot"));
bc95_serial.println(F("AT+CGDCONT=1,\"IP\",\"lpwa.vodafone.iot\""));
delay(1000);
Serial.println(F("AT+CGDCONT?"));
bc95_serial.println(F("AT+CGDCONT?"));
bc95_serial_read();
* funciton name :mcu_at_nconfig()
* parameter :NONE
* effect :send AT+NCONFIG command,look for NB-IoT message of config
* data :2018/4/16
void mcu_at_nconfig()
while(1) {
Serial.println(F("AT+NCONFIG?")); //
bc95_serial.println(F("AT+NCONFIG?")); //send "AT+NCONFIG"command
bc95_serial_read(); //return the value
if(strstr(retmcu, "+NCONFIG:AUTOCONNECT,FALSE") != NULL) { //if return value isn't"+NCONFIG:AUTOCONNECT,FALSE",this isn't auto look for network......
Serial.println(F("AT+NCONFIG=AUTOCONNECT,TRUE")); //
bc95_serial.println(F("AT+NCONFIG=AUTOCONNECT,TRUE")); //then send for"AT+NCONFIG=AUTOCONNECT,TRUE"command to NB-IoT
reboot = 1; //1reboot module laber is "1"
break; //break the while(1)
} else if (strstr(retmcu, "+NCONFIG:AUTOCONNECT,TRUE") != NULL) {//
break; //
} else { //this is else if wait for appear return is ture
Serial.println("Nothing happening, repeating process");
//Do Nothing
// Serial.println("AT Config done****");
* funciton name :mcu_at_csq()
* parameter :NONE
* effect :send "AT+CSQ"command,look for singal strengh
* data :2018/4/16
void mcu_at_csq()
// Serial.println("Check for signal strength, 99 means no signal *****");
while(1) {
Serial.println(F("AT+CSQ"));
bc95_serial.println(F("AT+CSQ"));
bc95_serial_read();
if(strstr(retmcu, "+CSQ:99,99") != NULL) { // res 99 is nosignal
// Serial.println("No signal...");
continue;
} else if (strstr(retmcu, "+CSQ:") != NULL) {
break;
} else {
// Do Nothing
// Serial.println("Finished - Check for signal strength, 99 means no signal *****");
* funciton name :mcu_at_cgatt()
* parameter :NONE
* effect :send "AT+CGATT"command,detect network if activate
* data :2018/4/16
void mcu_at_cgatt()
while(1)
bc95_serial_clearbuf(); //clear the send buffer
Serial.println(F("AT+CGATT?"));
bc95_serial.println(F("AT+CGATT?")); //"AT+CGATT"command
if(strstr(retmcu, "+CGATT:1") != NULL) { //return value 1:active,0:disavtive
break; //active break while
* funciton name :mcu_at_cfun()
* parameter :NONE
* effect :send "AT+CFUN"command,enable Receive and send
* data :2018/4/16
void mcu_at_cfun()
while(1) {
Serial.println(F("AT+CFUN?"));
bc95_serial.println(F("AT+CFUN?")); //send "AT+CFUN"command to NB-IoT module
bc95_serial_read(); //read return value
if(strstr(retmcu, "+CFUN:1") != NULL) { //if return value is"1",reprense NB-IoT enable receive and send port,at the moment break the while
break;
} else { //or wait for return is"1"
//Do Nothing
* funciton name :mcu_at_cereg()
* parameter :NONE
* effect :send "AT+CEREG"command,look for EPS network is register state
* data :2018/4/16
//void mcu_at_cereg()
// while(1)
// bc95_serial_clearbuf(); //clear the buffer
// Serial.println(F("AT+CEREG?"));
// bc95_serial.println(F("AT+CEREG?")); //send "AT+CEREG?"command to NB-IoT
// bc95_serial_read();
// if(strstr(retmcu, "+CEREG:0,1") != NULL) { // res +CEREG:n,stat , stat=2 indicate not registered
// break;
// if(strstr(retmcu, "+CEREG:5,1") != NULL) {
// break;
void mcu_at_cereg()
// while(1)
Serial.println(F("AT+CEREG=5"));
bc95_serial.println(F("AT+CEREG=5")); //send "AT+CEREG?"command to NB-IoT
bc95_serial_read();
// break;
// break;
* funciton name :mcu_at_cscon()
* parameter :NONE
* effect :send "AT+CSCON"command
* data :2018/4/16
void mcu_at_cscon()
while(1)
Serial.println(F("AT+CSCON?"));
bc95_serial.println(F("AT+CSCON?"));
bc95_serial_read();
if(strstr(retmcu, "+CSCON:0,1") != NULL) { //res +CSCON:n,mode , if mode=1 connected, 0 idle
break;
* funciton name :mcu_at_ncdp()
* parameter :NONE
* effect :send "AT+NCDP"command,config and look for CDP server
* data :2018/4/16
void mcu_at_ncdp()
while(1) {
Serial.println(F("AT+NCDP?"));
bc95_serial.println(F("AT+NCDP?"));
bc95_serial_read(); //query the "AT+NCDP"command,read return value
if(strstr(retmcu, server) != NULL) //return value is not NULL,break the while
break;
else {
Serial.println(F("AT+CFUN=0"));
bc95_serial.println(F("AT+CFUN=0"));
bc95_serial_read(); //send "AT+CFUN=0"command and read return value
if(strstr(retmcu, "OK") != NULL) { //
char cmd[32] = {'\0'};
snprintf(cmd, sizeof(cmd), "AT+NCDP=%s,%d",server, port);
bc95_serial.println(cmd);
bc95_serial_read();
bc95_serial.println(F("AT+CFUN=1"));
delay(500);
break;
* desc: send a message from the terminal to network via connect
* device platform server. (CDP)
* ret: return 0 if send message success
int mcu_at_nmgs(int len, char *data)
char cmd[256] = {'\0'};
snprintf(cmd, sizeof(cmd), "AT+NMGS=%d,%s", len, data);
Serial.println(cmd);
delay(1000); //wait 1 sencond
bc95_serial_read();
return 0;
return 1;
* desc: Queries the status of downstream messages received from
* the CDP server
* Res: BUFFERED=<num>, RECENIVED=<num>, DROPPED=<num>
* +CME ERROR:<err>
void mcu_at_nqmgr()
Serial.println(F("AT+NQMGR"));
bc95_serial.println(F("AT+NQMGR"));
bc95_serial_read();
* the CDP server
* note:
int i;
char *sp, buf[8];
mcu_at_nqmgr();
if ((strstr(retmcu, "BUFFERED=")) != NULL) {
sp = strchr(retmcu, '=');
for (i = 0; sp[i] != ',', i < 8; i++) {
buf[i] = sp[i + 1];
buf[i] = '\0';
if (atoi(buf) > 0)
mcu_at_nmgr();
* desc: Queries the status of the upstream messages
* sent to the CDP server
* note:
* Res: PENDING=<num>, SENT=<num>, ERROR=<num>
void mcu_at_nqmgs()
Serial.println(F("AT+NQMGS"));
bc95_serial.println(F("AT+NQMGS"));
bc95_serial_read();
* desc: return the oldest buffered message and deletes from buffer
* note: if new message indications(AT+NNMI)are turn on then received
* messages will not be available via this command
void mcu_at_nmgr()
Serial.println(F("AT+NMGR"));
bc95_serial.println(F("AT+NMGR"));
bc95_serial_read();
* desc: create udp socket
* * AT+NSOCR=<type>,<protocol>,<listen port>[,<recive control>]
* * udp type:DGRAM, protocol:17, receive control default is 1 message will be receive
* note: if a socket has already created, will fail if requested a second time
void mcu_at_nsocr()
Serial.println(F("AT+NSOCR=DGRAM,17,5999,1"));
bc95_serial.println(F("AT+NSOCR=DGRAM,17,5999,1"));
bc95_serial_read();
* desc: send data to udp server
* AT+NSOST=socket,remote_addr,remote_port, length, data
* socket: number return by AT+NSOCR, 0 as default
void mcu_at_nsost(int len, char *data)
int i;
char imeihex[32] = {'\0'};
char datahex[MAXLEN] = {'\0'};
str2hex(imeihex, sizeof(imeihex), IMEI, strlen(IMEI));
str2hex(datahex, sizeof(datahex), data, len);
snprintf(retmcu, sizeof(retmcu), "AT+NSOST=0,%s,%d,%d,%s3D%s", udpserver, port, len + strlen(IMEI) - 1, datahex, imeihex);
bc95_serial.println(retmcu);
bc95_serial_read();
* desc: read the req_length characters of data from socket
void mcu_at_nsorf()
Serial.println(F("AT+NSORF=0,512")); // read 512 characters form socket 0
bc95_serial.println(F("AT+NSORF=0,512")); // read 512 characters form socket 0
bc95_serial_read();
if(strstr(retmcu, "+NSONMI:") != NULL) { // +NSONMI: has message
bc95_serial_read();
* funciton name :mcu_at_cgpaddr()
* parameter :*ip
* effect :send "AT+CGPADDR"command,display the PDP addr
* data :2018/4/16
void mcu_at_cgpaddr()
Serial.println(F("AT+CGPADDR"));
bc95_serial.println(F("AT+CGPADDR"));
bc95_serial_read();
* funciton name :mcu_at_nping()
* parameter :*ip
* effect :ping
* data :2018/4/16
void mcu_at_nping(char *ip)
char cmd[64] = {'\0'};
snprintf(cmd, sizeof(cmd), "AT+NPING=%s", ip); //函数原型为int snprintf(char *str, size_t size, const char *format, ...)
void mcu_at_natspeed(void){
Serial.println(F("AT+NATSPEED?"));
bc95_serial.println(F("AT+NATSPEED?"));
// if ( bc95_serial.available() ) { Serial.println( bc95_serial.read() ); }
// if ( bc95_serial.available() ) { Serial.write( bc95_serial.read() ); }
bc95_serial_read(); // reads and prints to serial monitor.
delay(1000);
* funciton name :mcu_init()
* parameter :NONE
* effect :init the NB-IoT module
* data :2018/4/16
void mcu_init()
mcu_at_natspeed();
mcu_at_nband(); //choose the NB-IoT working band
mcu_at_nconfig(); //config auto look for network
if (reboot) {
reboot = 0; //
mcu_at_nrb(); //reboot the NB-IoT module
delay(5000); //delay 5 second
if (NULL == mcu_get_imei(IMEI))//if return value is null,Arduino Send char string to computer port
Serial.println(F("IMEI = NULL"));
else {
Serial.print(F("IMEI="));
Serial.println(IMEI); //else Arduino send IMEI code to computer port
Serial.println("Getting the IMEI done ***");
// mcu_at_ncdp(); //query IP addr if using CDP interface. Not for us though, right? How disable? Comment out?
mcu_at_csq(); //query signal strengh
Serial.println("Query signal strength done****");
mcu_at_cgatt(); // Attach to network
Serial.println("CGATT done****");
mcu_at_cereg(); //check the EPS network registration status.
Serial.println("CEREG done ******");
mcu_at_cgdcont(); //
Serial.println("CGD done ******");
mcu_at_cgpaddr(); // Show PDP/IP addresses
Serial.println("CGP done ******");
mcu_at_nsocr(); // Greate a SOcket
Serial.println("create socket done ******");
* desc : Send data via UDP
void send_data_udp(int len, char *data)
mcu_at_nsost(len, data);
* desc : Receive data via UDP. Not sure if this fuction actually works.
void mcu_rec_data()
mcu_at_nsorf();
