Hi there!
Commands like at+qcfg=“nwscanseq”,03, at+qcfg=“nwscanmode”,3 and at+qcfg=“iotopmode”,1 change settings that are stored in the BG96 module’s non-volatile memory.
Is there a command to reset the module’s non-volatile settings to a default state? I suspect that I may have corrupted the non-volatile memory and want to reset it so that I can start from a clean slate again.
Thanks in advance,
Pieter
Hi Leonardus and Stephen,
Thank you for sharing the command. It worked
@Leonardus Thanks for pointing out that it will wear out Flash (that’s important to know!).
Best regards,
Pieter
@Stephen.Li-Q Thanks for sharing the new AT command
Is there a document that describes these commands?
Thanks in advance,
Pieter
@piconomix
Restore NV is not a normal operation and is not recommended to be used frequently. These two commands are internal commands for R & D, and there is no external document to release . If you really need restore NV, Just do it .
Hi zazas..are you solved the BG95-m3 factory reset
