Hi everyone,
I have a lot of problems with del module BC66 (FW: BC66NBR01A10) sending UDP packets with OpenCPU V1.5
I am using the library ql_socket, that it seems to be It is more recommendable than ril_socket.
I think I know which the problem is, but I don’t know to solve it.
I am using the function Ql_SOC_SendTo to send data by UDP, when the IP server is a hostname I have to use the function Ql_IpHelper_GetIPByHostName and everything works fine apparently, but sometimes the function Ql_IpHelper_GetIPByHostName fail, and I don’t know what to manage this error. You can see this ticket: Problems with the fucntion Ql_IpHelper_GetIPByHostName using OpenCPU
So I decided to use a fixed IP instead a hostname in order to avoid using the function Ql_IpHelper_GetIPByHostName, but know It seems to be that the function Ql_SOC_SendTo is executed successfully but the module BC66 isn’t in RCC_CONNECTED mode so the Tx doesn’t occur but I don’t get any error, so I am sure that the UDP Tx fails due to the fact the module is in IDLE.
The question is: ¿How can I make sure that the module is in RCC_CONNECTED state before trying to send an UDP packet?
