I am using the BC66 module with OpenCPU. Is there any way to use the DOTA mode to update not only the FW besides I would like to update the embedded application?
I think there is probably a way to copy the binary part related to the embedded application inside the binary firmware.
I’ve checked the example called: example_dfota_http.c for updating the binary (SDK v1.5).
I’ve placed the binary I want to upgrade in a http server, and when the example: example_dfota_http.c executes the function RIL_DFOTA_Upgrade(m_URL_Buffer), I can see with my power analyzer current peaks for a while, so it seems to be that something is working, but eventually, I get the error DFOTA_FAILED.
In the example I could read these instructions:
* Operation:
* step 1: you must put your application bin in your server.
* step 2: replace the “APP_BIN_URL” with your own .
* step 3: input string : start dfota=XXXX, XXXX stands for URL.
* The URL format for http is: http://hostname:port/filePath/fileName
* NOTE: if “:port” is be ignored, it means the port is http default port(80)
* eg1: http://23.11.67.89/file/xxx.bin
* eg2: http://www.quectel.com:8080/file/xxx.bin
So they don’t talk about differential binary file for the application. Do I have to use a differential binary for the app? I the answer is yes, Do you know how I have to do that?
Hi Oscargomezf
Please provide the error DFOTA_FAILED log.
Please make sure that the HTTP server is using a differential package instead of a full file package.
As I told you, I am using a binary. When I compile I get the file: APPGS3MDM32A01.bin. I am not using a differential binary. How can I build a differential binary?
By the way, How can I get the log for the error DFOTA_FAILE? Do you want me to use Genie for that?
Is there any documentation about how to do it? I don’t know If I am doing well.
These are the steps I followed:
1º. Generate a binary and compressed in rar format called [old binary]: APPGS3MDM32A01_old.rar
2º. Upload the binary by UART to the BC66 module with this binary.
3º. Change the app, compile and generate a new .rar: APPGS3MDM32A01_new.rar
4º. Enter in the website: http://dfota.quectel.com:8081 and upload the files: APPGS3MDM32A01_new.rar and APPGS3MDM32A01_old.rar.
5º. Click the button “+Start making” to generate the diff file and dowload it. The name is: APPGS3MDM32A01_new-APPGS3MDM32A01_old.rar
Thank you very much for the documentation. Now is much more clear for me.
I have the last question: According to the documentation If I want to do an upgrade, I need the folder new-old. I have to rename the .update.dela of this folder to the name app_bc66_tst.bin, due to the fact, I have configured this name in my app, and place this app_bc66_tst.bin on my http server (http://my.host.name/fw):
I trying to access to the dfota website, in order to check the upagrades FW, but it seems to be that the website is down: http://dfota.quectel.com:8081/
Would you mind confirming me that the website is properly working?
Right now I can access the website. But it doesn’t work the upgrade. I’ve got the same error: DFOTA_FAILED (Error number 8). These are the steps I’ve followed:
1º. Generate a binary and compressed in RAR format called [old binary]: APPGS3MDM32A01_old.rar
5º. Click the button “+Start making” to generate the diff file and download it. The name is: APPGS3MDM32A01_new-APPGS3MDM32A01_old.rar
6º. Unrar the file: APPGS3MDM32A01_new-APPGS3MDM32A01_old.rar and get the file: APPGS3MDM32A01_OLD-APPGS3MDM32A01_NEW\update.delta and rename to app_bc66_tst.bin.
7º. Upload the file app_bc66_tst.bin to my HTTP server.
8º. Force my device to execute the function RIL_DFOTA_Upgrade(APP_BIN_URL), to start the upgrade.
Do you have any suggestions? I think I am following the process correctly.
According to: “Is the URL in the RIL_DFOTA_Upgrade function in example_dfota_http.c modified?”
Yes. And I’ve checked with the command wget (from a linux computer) that the binary file is accessible from the HTTP server.
According to: “Your steps Are you going to downgrade?”
I want to make an upgrade so I need to get the .delta file from the folder APPGS3MDM32A01OLD-APPGS3MDM32A01NEW. What is to say, right now I have the fw OLD and I want to change to the NEW. Is that right?
From your previous process, you are downgrading. Please also confirm the process.
I suspect that something went wrong in your process of making the difference package.
You can try a few more times.
