[Yocto][SC206] Recovery test failure and OTA problems
I´ve built an image using the QCM2290 SDK v1.8. Then I tried to perform the Recovery Test described in the Quectel_SC206E_Series_Linux_User_Guide_V1.0.0_Preliminary_20240329.pdf file
But the txt file is not deleted from the /data/ folder.
Then I followed the steps described in the PDF file
QCM2290_OTA_Upgrade_Operation.pdf
But the update is not installed and in /cache/recovery I only find the file command
I’m trying to figure out how to apply te FOTA procedure in order to update de image, but I think that the module cannot enter to Recovery mode. I may add, that when I try to enter to Recovery mode through fast boot, the module just restarts to Normal mode (Weston GUI is shown in the display)
According to the SC206EEMNAR60A03_BP01.003_Linux5.4.191.01.002 package I provided before and guided you to operate, I found that your upgrade was successful through the return value of last_install.
For other OTA issues, please open tickets in our e-service system
