[Yocto] [SC206] network manager not showing WIFI networks
I’ve added the package networkmanager in the file local.conf (poky/qti-conf)
I’ve connected the SC206 SoC using wpa_cli -i wlan0 commands.
Then I’ve realized that the wlan0 was unmanaged by nmcli. So I changed this, but the wlan0 device showed as disconnected. Also, i’ve tried to scan wifi networks, but i didn´t get any result.
In conclusion i’m not able to manage wifi connection with nmcli, and I’m looking to do it because i’ll try to configure Static IP’s in different wifi networks.
We connect to wifi in the following ways.
You can set your own wifi name and password
/ # wpa_cli
wpa_cli v2.5-devel
Copyright (c) 2004-2015, Jouni Malinen j@w1.fi and contributors
This software may be distributed under the terms of the BSD license.
See README for more details.
Selected interface ‘wlan0’
Interactive mode
scan
<3>CTRL-EVENT-SCAN-STARTED
wlan0: CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=CN
<3>CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=CN
<3>CTRL-EVENT-SCAN-RESULTS
<3>CTRL-EVENT-NETWORK-NOT-FOUND
scan_results
bssid / frequency / signal level / flags / ssid
7c:d9:a0:0f:9a:32 5260 -53 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
7c:d9:a0:0f:9a:30 5260 -53 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer
08:4f:0a:a7:32:90 5260 -60 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer
08:4f:0a:a7:32:92 5260 -61 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
10:c1:72:1d:8b:50 5260 -63 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer
10:c1:72:1d:8b:52 5260 -64 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
b8:e3:b1:12:72:62 5260 -65 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
b8:e3:b1:12:72:60 5260 -65 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer
7c:d9:a0:0f:9a:23 2452 -44 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
7c:d9:a0:0f:9a:22 2452 -44 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF-2.4G
7c:d9:a0:0f:9a:20 2452 -44 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer-2.4G
08:4f:0a:a7:32:82 2432 -47 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF-2.4G
08:4f:0a:a7:32:80 2432 -47 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer-2.4G
48:01:c5:5d:4a:0c 2412 -50 [WPA2-PSK-CCMP][ESS] 12345
b8:e3:b1:12:72:53 2452 -59 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
b8:e3:b1:12:72:52 2452 -59 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF-2.4G
b8:e3:b1:12:72:50 2452 -59 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer-2.4G
10:c1:72:1d:8b:42 2432 -55 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF-2.4G
10:c1:72:1d:8b:40 2432 -55 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer-2.4G
44:6a:2e:13:cc:70 5260 -75 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer
44:6a:2e:13:cc:72 5260 -76 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
7c:d9:a0:0f:96:a2 2412 -71 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF-2.4G
7c:d9:a0:0f:96:a3 2412 -72 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
f4:b7:8d:85:d4:b0 5260 -80 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer
b8:e3:b1:12:7c:20 5785 -81 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer
f4:b7:8d:85:d4:b2 5260 -81 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
10:c1:72:1d:32:c0 2432 -74 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer-2.4G
7c:d9:a0:0f:96:a0 2412 -74 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer-2.4G
b8:e3:b1:12:7c:22 5785 -82 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
b8:e3:b1:12:7a:10 2452 -78 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer-2.4G
f4:b7:8d:85:d4:32 5180 -89 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
f4:b7:8d:85:d4:30 5180 -90 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer
44:6a:2e:12:0c:72 5180 -91 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
44:6a:2e:12:0c:70 5180 -91 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer
10:c1:72:1d:32:d2 5785 -93 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
add_network
0
add_network 1
3
set_network 3 ssid “Quectel-Customer”
set_network 3 psk “Customer-Quectel”
enable_network 3
wlan0: Trying to associate with SSID ‘Quectel-Customer’
<3>Trying to associate with SSID ‘Quectel-Customer’
eap_proxy: eap_proxy_notify_config
eap_proxy: eap_proxy_allowed_method
wlan0: Associated with 7c:d9:a0:0f:9a:30
<3>Associated with 7c:d9:a0:0f:9a:30
wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
<3>CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
wlan0: WPA: Key negotiation completed with 7c:d9:a0:0f:9a:30 [PTK=CCMP GTK=TKIP]
<3>WPA: Key negotiation completed with 7c:d9:a0:0f:9a:30 [PTK=CCMP GTK=TKIP]
wlan0: CTRL-EVENT-CONNECTED - Connection to 7c:d9:a0:0f:9a:30 completed [id=3 id_str=]
<3>CTRL-EVENT-CONNECTED - Connection to 7c:d9:a0:0f:9a:30 completed [id=3 id_str=]
wlan0: WPA: Group rekeying completed with 7c:d9:a0:0f:9a:30 [GTK=TKIP]
<3>WPA: Group rekeying completed with 7c:d9:a0:0f:9a:30 [GTK=TKIP]
> status
bssid=7c:d9:a0:0f:9a:30
freq=5260
ssid=Quectel-Customer
id=3
mode=station
pairwise_cipher=CCMP
group_cipher=TKIP
key_mgmt=WPA2-PSK
wpa_state=COMPLETED
ip_address=10.66.178.122
p2p_device_address=00:0a:f5:43:11:6c
uuid =97b2bdeb-80a7-559c-8d76-b0f0ac40a881
> quit
/ # ifconfig
bridge0 Link encap:Ethernet HWaddr 4E:5E:D0:B3:7B:6F
inet addr:192.168.225.1 Bcast:192.168.225.255 Mask:255.255.255.0
inet6 addr: fe80::4c5e:d0ff:feb0:786c/64 Scope:Link
UP BROADCAST PROMISC MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:192 errors:0 dropped:0 overruns:0 frame:0
TX packets:192 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:12368 (12.0 KiB) TX bytes:12368 (12.0 KiB)
rmnet_data0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:10.64.88.16 Mask:255.255.255.224
UP RUNNING MTU:1500 Metric:1
RX packets:19815 errors:0 dropped:0 overruns:0 frame:0
TX packets:92682 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3163833 (3.0 MiB) TX bytes:24623631 (23.4 MiB)
rmnet_ipa0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
UP RUNNING MTU:2000 Metric:1
RX packets:16798 errors:0 dropped:0 overruns:0 frame:0
RX bytes:3401613 (3.2 MiB) TX bytes:25365087 (24.1 MiB)
wlan0 Link encap:Ethernet HWaddr 00:0A:F5:43:11:6C
inet addr:10.66.178.122 Bcast:10.66.183.255 Mask:255.255.248.0
inet6 addr: fe80::20a:f5ff:fe43:116c/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:58 errors:0 dropped:0 overruns:0 frame:0
TX packets:25 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:16580 (16.1 KiB) TX bytes:2776 (2.7 KiB)
/ # ping baidu.com
PING baidu.com (110.242.68.66) 56(84) bytes of data.
64 bytes from 110.242.68.66: icmp_req=1 ttl=53 time =70.6 ms
64 bytes from 110.242.68.66: icmp_req=2 ttl=53 time =70.1 ms
64 bytes from 110.242.68.66: icmp_req=3 ttl=53 time =70.1 ms
64 bytes from 110.242.68.66: icmp_req=4 ttl=53 time =69.3 ms
