YC0001CA footprint clarification
Hi, I need clarification on what the correct pinout and footprint is for the Quectel YC0001CA antenna is. There appears to be some conflict in the datasheet on which pin is the feed and which is the ground return pin.
Surely the pin on the left is the GND and then the pin on the right is the feed with the PI network.
Also both of these drawings conflict:
Please if somebody from Quectel could respond to this!
Thank you.
@brown.du-Q hi brown, please help support this issue, many thanks~
Hi ,
Pin9 is feed and Pin10 is GND.
