Which is in ~/linux folder?
I am building fghm100 driver, I found that the build command as
make MORSE_TRACE_PATH=pwd ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- KERNEL_SRC=~/linux CONFIG_WLAN_VENDOR_MORSE=m CONFIG_MORSE_SDIO=y CONFIG_MORSE_USER_ACCESS=y
Please tell me which is in ~/linux? and which version of linux in that folder and where to get it?
BR
MEQ
hello, may we know your current module type, thanks
SDX35 with fghm100 halow.
@Niki.Liu-Q
Any update for this question?
sorry,I can’t find this command, I will share you the last user guide ,based on RK3568 Linux 4.19.232 SDK
The command is in README file of that driver fgh100.
~/linux should be the Linux kernel code for the x35.
In another topic it seems that you already have intergrated the FGHM100.
