Where is Diag port in RG500L-EU EVB?
Which one of serial port in RG500L-EU EVB is diagnostic port (DM Port)? I couldn’t find diag port. thank a lot .
If you have installed the driver correctlly, when you connect the USB port, you will see three ports in device manager which are AT port;DM port;NEMA port
Thanks dear Brayan.
Best Regards
I installed driver. I cant see ttyUSB0-ttyUSB4 and only ttyUSB1-2 would be appear.
Screenshot from 2022-09-10 14-54-29
Screenshot from 2022-09-10 14-57-26
Hi @rira,
The RG500L series seems to be based on a MediaTek chipset and not on a Qualcomm chipset like the RG500Q/RM500Q series (which is already supported in the mainline linux kernel for some time now).
Can you please share the output of sudo lsusb -d 2c7c: -vv and/or sudo cat /sys/kernel/debug/usb/devices as text and not images?
Regards,
Reinhard
Hi Dear rspmn,
thank a lot for your response.
output of sudo cat /sys/kernel/debug/usb/devices is :slight_smile:
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 2
B: Alloc= 0/800 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0002 Rev= 4.15
S: Manufacturer=Linux 4.15.0-191-generic ehci_hcd
S: Product=EHCI Host Controller
S: SerialNumber=0000:00:1a.0
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 4 Ivl=256ms
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 6
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=8087 ProdID=800a Rev= 0.05
E: Ad=81(I) Atr=03(Int.) MxPS= 1 Ivl=256ms
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 2
S: SerialNumber=0000:00:1d.0
T: Bus=02 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 8
P: Vendor=8087 ProdID=8002 Rev= 0.05
E: Ad=81(I) Atr=03(Int.) MxPS= 2 Ivl=256ms
T: Bus=03 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh=15
S: Manufacturer=Linux 4.15.0-191-generic xhci-hcd
S: Product=xHCI Host Controller
S: SerialNumber=0000:00:14.0
T: Bus=03 Lev=01 Prnt=01 Port=02 Cnt=01 Dev#= 2 Spd=1.5 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=1a81 ProdID=1006 Rev= 1.20
S: Manufacturer=KYE
S: Product=Wireless keyboard and mouse
C:* #Ifs= 2 Cfg#= 1 Atr=a0 MxPwr= 98mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=01 Prot=01 Driver=usbhid
E: Ad=81(I) Atr=03(Int.) MxPS= 8 Ivl=10ms
I:* If#= 1 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=01 Prot=02 Driver=usbhid
E: Ad=82(I) Atr=03(Int.) MxPS= 8 Ivl=10ms
T: Bus=03 Lev=01 Prnt=01 Port=08 Cnt=02 Dev#= 3 Spd=480 MxCh= 4
D: Ver= 2.10 Cls=09(hub ) Sub=00 Prot=02 MxPS=64 #Cfgs= 1
P: Vendor=174c ProdID=2074 Rev= 0.01
S: Manufacturer=ASUS TEK.
S: Product=ASM107x
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=100mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=01 Driver=hub
I:* If#= 0 Alt= 1 #EPs= 1 Cls=09(hub ) Sub=00 Prot=02 Driver=hub
T: Bus=03 Lev=02 Prnt=03 Port=00 Cnt=01 Dev#= 5 Spd=12 MxCh= 0
P: Vendor=0b05 ProdID=185d Rev= 1.07
S: Product=ASUS GT300 GAMING MOUSE
C:* #Ifs= 4 Cfg#= 1 Atr=a0 MxPwr=400mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=01 Prot=02 Driver=usbhid
E: Ad=81(I) Atr=03(Int.) MxPS= 8 Ivl=1ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=03(HID ) Sub=00 Prot=00 Driver=usbhid
E: Ad=82(I) Atr=03(Int.) MxPS= 64 Ivl=1ms
E: Ad=05(O) Atr=03(Int.) MxPS= 64 Ivl=1ms
I:* If#= 2 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=01 Prot=01 Driver=usbhid
E: Ad=84(I) Atr=03(Int.) MxPS= 8 Ivl=1ms
I:* If#= 3 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=00 Prot=00 Driver=usbhid
E: Ad=83(I) Atr=03(Int.) MxPS= 16 Ivl=1ms
T: Bus=03 Lev=01 Prnt=01 Port=09 Cnt=03 Dev#= 4 Spd=480 MxCh= 4
S: Product=ASM107x
T: Bus=03 Lev=01 Prnt=01 Port=12 Cnt=04 Dev#= 12 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=ff(vend.) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=1a86 ProdID=7523 Rev= 2.64
S: Product=USB Serial
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr= 98mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=01 Prot=02 Driver=ch341
E: Ad=82(I) Atr=02(Bulk) MxPS= 32 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 32 Ivl=0ms
T: Bus=03 Lev=01 Prnt=01 Port=13 Cnt=05 Dev#= 11 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=10c4 ProdID=ea60 Rev= 1.00
S: Manufacturer=Silicon Labs
S: Product=CP2102 USB to UART Bridge Controller
S: SerialNumber=0001
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=100mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=cp210x
E: Ad=81(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
T: Bus=04 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=5000 MxCh= 6
D: Ver= 3.00 Cls=09(hub ) Sub=00 Prot=03 MxPS= 9 #Cfgs= 1
P: Vendor=1d6b ProdID=0003 Rev= 4.15
T: Bus=04 Lev=01 Prnt=01 Port=04 Cnt=01 Dev#= 2 Spd=5000 MxCh= 4
P: Vendor=174c ProdID=3074 Rev= 0.01
S: Product=ASM107x
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 8mA
E: Ad=81(I) Atr=13(Int.) MxPS= 2 Ivl=16ms
T: Bus=04 Lev=01 Prnt=01 Port=05 Cnt=02 Dev#= 3 Spd=5000 MxCh= 4
S: Product=ASM107x
Best Regard,
That’s strange. Provided that the EVK has been configured correctly and the device is powered on I would have expected to see an entry with Vendor=2c7c - at least that was the case with the RG500Q EVB I was using.
For a MediaTek-based device the entry would probably look similar to Making sure you're not a bot! .
Regards,
Reinhard
