I have sent you the latest driver. At the same time, you need to refer to the upgrade method described in the Qflash user manual.
I am using a Quectel EC25-AFXD module.
Current firmware:
EC25AFXDGAR07A01M1G_01.002.01.002
Could you please share the latest available firmware for this module?
You can send it to my email: chanwei@fastmail.com
Thank you.
I need the latest firmware and flashing tool for EC25-A module, please.
I have a modem with firmware EC25EUXGAR08A19M1G that can’t register to a network. Is there a newer firmware version?
I’d also need the flashing tool.
Hi, my EG91EFB is in a cyclical reboot due to missing partitions.
I was able to enter fastboot mode over USB.
fastboot devices returns:
ee74cf99 fastboot
fastboot getvar all shows:
version: 0.5
kernel: lk
product: MDM9607
serialno: ee74cf99
version-baseband: blank
version-bootloader: blank
fastboot oem device-info shows:
Device tampered: false
Device unlocked: false
I also checked the partitions mentioned in the boot log:
fastboot getvar partition-size:devinfo
partition-size:devinfo:
fastboot getvar partition-size:config
partition-size:config:
fastboot getvar partition-size:frp
partition-size:frp:
These return blank, which seems to match the debug log errors:
ERROR: No devinfo partition found
Neither ‘config’ nor ‘frp’ partition found
Does this indicate that the partition table or firmware image is corrupted/incomplete? If so, could someone provide the correct signed full recovery firmware / firehose package and flashing procedure for EG91-EFB-512-SNND?
Hi there,
I also need the modem firmware for EM160R-GL, as our products can’t bootup with “can’t find FW“
vender : Quectel
product : Quectel
model : EM160R-GL
SIM slot : SIM2
revision : EM160RGLAUR02A08M4G_01.001.01.001
