Hello there. I’m devoloping a website server using M95 module as TCP Server, and everything was good. However, today whenever i try to connect it via IP address, resets itself. I’m using GSM2 Click development board, so I can see the reset situation with the STAT Led, it turns off then on again, and my command prompt shows me again Call Ready stuff. The other AT commands runs perfectly, I’m using it nearly 1 months and never encounter a problem like this.
I thought it was a power problem, but as i said before, i never encounter a problem like this until this day. I’m using 0-30V 5A power supply to run it.
I hope you may get me, sorry for my language.
Best regards.
