What you need to do to connect the BG95M3 to 2G
Hello.
I usually operate BG95M3 on LTE network. I would like to change the configuration of this to support operation on a 2G network (GSM).
What are the necessary configuration items for this?
The current procedure to connect to the network is as follows.
ATE
AT+GSN
AT+QCCID
AT+GMR
AT+CGDCONT=1, “IP”, “xx.xxxx.net”
AT+QICSGP=1,1, “xx.xxxx.net”, “xxx@xxx”, “xxxxxxxx”,3
AT+QGPSCFG=“priority”,1,1
AT+COPS=1,2, “44010”
AT+COPS?
AT+CSQ
AT+QCFG=“NWSCANMODE”,1;+QCFG=“NWSCANSEQ”,010101
Above command is to force BG95 in GSM Only mode.
AT+QCFG=“NWSCANMODE”,0;+QCFG=“NWSCANSEQ”,010302
And this command is for GSM Preffered mode.
