EC21
Custom board
After using AT+GPS=1
I get the URC: +QODM: “FUMO”, Report Failed
Where is this documented?
I have a bunch of PDF files for the EC21 but I can’t search all of them at once.
Do you have a web page that I can search for commands, responses, and URC messages?
What does it mean?
Thanks,
Bruce Graham
Senior Software Engineer
TechnoSoft Innovations, Inc. bgraham@technosofteng.com
I did not find QODM in the docs.
I guess that there is a command like AT+QODM that would produce a URC.
I do not use a QODM command, so why is the EC21 sending the QODM URC?
Dear Mdean,
For this issue, you can try the following method to disable this information. Thanks!
This URC information is related to AT&T OMA DM function, if it have no any influence on your application, please skip it; if it already have the effect on your application, you can use the following command to disable it, it will take effect after reboot. Thanks!
at+qodm=“fumo”,1,“autoreport 0”
Dear Richardl,
I have try this command in my side, this version can not support it. You may need to upgrade two higher version to support this command. Thanks!
Thank you Kyson, I will try with the firmware update, meanwhile, I have a few questions about this issue:
We have thousands of product with EC21 already in end customer’s hand, how to make firmware update seamlessly from there? does the older version has DFOTA support?
Luckily we just have few test board has such issue internally (triggered by bug somewhere in a new development), but we still have to prevent this happen in any case, is there any workaround to prevent this without firmware update? such as AT&F or some undocumented command? (I tested AT&F but doesn’t help).
I am working on new module BG95M3 as well, should I add this command into there too?
Dear Richardl,
Sorry for bring any inconvenience for you.
Could you help to leave the message of your company name and your country, your email. Or you can send email to support@quectel.com, then we will arrange local FAE to guide you how to solve this issue. Thanks!
