What is a RAM and Flash size of the BC660K module?
Thanks,
Mukesh Prajapati
Thanks,
Mukesh Prajapati
30K - RAM;200K-APPcode;200K-FileSystem
Thanks for quick response.
Can you explain about APPcode, FileSystem?
We understood BC660K has 30K RAM and 200K flash for code.
Thanks,
Mukesh Prajapati
yes,You are right to understand
Again thanks for quick response.
But, can you explain about FileSystem memory?
Thanks,
Mukesh Prajapati
BC660K supports file system, similar to UFS
BC660K supports file system ??
I did not know…
What library is used? fatFS? or liteFS?
