Hi Quectel Team,
I am seeking assistance in obtaining specific network parameters from the EC25 Module. Unfortunately, I have not been able to locate any relevant commands in the AT Command datasheet. If these parameters are supported by the module, could you kindly provide me with instructions on how to access them?
You can use AT+QENG="servingcell" to get these data.
In the case of LTE mode:
+QENG: "servingcell",<state>,"LTE",<is_tdd>,<mcc>,<mnc>,<cellID>,<pcid>,<earfcn>,<freq_band_ind>,<ul_bandwidth>,<dl_bandwidth>,<tac>,<rsrp>,<rsrq>,<rssi>,<sinr>,<srxlev>
<sinr> Integer type. Logarithmic value of SINR. Range: -20–+30. Unit: dB.
hi ,I tried the AT command you mentioned above, but it keeps returning ERROR.
I am using this firmware version
EC25
Revision: EC25ECGAR06A09M1G
