Weird SIM card detection issue of RM520N-GLAA
Hi there, I have both RM520N-GLAA and RM500U-CN. RM500U-CN works perfectly in all of my devices ( M.2 key B to USB3 board, BPI-R3 mini, BPI-R4) but RM520N-GL only works in BPI-R4. RM520N-GL can be detected normally in all these 3 devices under openwrt or other linux distributions with command ‘lsusb’. The problem is that SIM card detection only works with BPI-R4. When using the module with the other two devices, AT+CPIN? always return CME ERROR 10. The only difference between the M.2 key B on BPI-R3 mini and that interface on BPI-R4 is BPI-R4’s M.2 key B supports both PCIE/USB mode. But the module is running under USB mode for sure or it should not be detected by lsusb. Could you please point out what is the possible explanation?
Dear @gesong2077
What is the current firmware of RM520NGLAA?
Do you check the interface by AT command?
AT+QCFG=“data_interface”
I haven’t checked the firmware of the module but I did check the interface with AT+QCFG=“data_interface”. I will get back to you with the actual firmware version and might need your help to upgrade the firmware
So I finally got chance to check this module again. Here are the screenshots under windows
And I’ve updated the firmware to RM520NGLAAR01A08M4G
The issue is still three. This module only works with my BPI-R4 board, other devices such as BPI-R3 mini and USB M.2 KEY B converter can detect the module but AT+CPIN always return error
AT+QSIMDET=1,1
AT+CFUN=1,1
saved the day
i got this error too, i’m following romulans guide for the rework enclosure, and i can’t get sim cards to be recognized.
I have tried this in another b-key, and also cannot read the sim from there, /* Use ATI to get module information of Manufacturer ID, Device modle and Firmware version */
[2025-04-29 14:47:36:578_S:] ATI
[2025-04-29 14:47:36:635_R:] ATI
[2025-04-29 14:47:36:635_R:] Quectel
[2025-04-29 14:47:36:635_R:] RM520N-GL
[2025-04-29 14:47:36:635_R:] Revision: RM520NGLAAR01A08M4G
[2025-04-29 14:47:36:635_R:] OK
/* Use AT+CPIN? to query the SIM card status : SIM card inserted or not, locked or unlocked */
[2025-04-29 14:47:38:731_S:] AT+CPIN?
[2025-04-29 14:47:38:791_R:] AT+CPIN?
[2025-04-29 14:47:38:791_R:] +CME ERROR: 10
/* Make sure SIM card is inserted */
/* Use AT+QCCID to query ICCID number of SIM card */
[2025-04-29 14:47:41:346_S:] AT+QCCID
[2025-04-29 14:47:41:414_R:] AT+QCCID
[2025-04-29 14:47:41:414_R:] +CME ERROR: 13
Dear @Kragoth
Do you use Qnavigator for testing?
If yes, please don’t use this, it doesn’t support 5G module.
Please download QCOM in website below for testing.
do you have a better link? i can’t find it at their landing page or the download section, I also notice within qnavigator there is a Qcom button. but either way, i can’t read a iccid, i hope to find the qcom download soon
