Hi Experts,
i am working with mc60 and i have connected external watchdog TPS3823 it’s working fine but i can’t upload the program i am getting below error because of MC60 booting time delay
i am using gpio0(57) pin for watchdog feed
i have already change the settings in Custom_sys_cfg.c
static const ST_ExtWatchdogCfg wtdCfg = {
PINNAME_GPIO0, // Specify a pin which connects to the external watchdog
PINNAME_END // Specify another pin for watchdog if needed
this is an example code
#ifdef EXAMPLE_WATCHDOG
#include “ql_type.h”
#include “ql_trace.h”
#include “ql_system.h”
#include “ql_timer.h”
#include “ql_wtd.h”
#include “ril.h”
#include “ril_util.h”
#include “ril_telephony.h”
#include “ql_uart.h”
#include “ql_stdlib.h”
#include “ql_error.h”
#define DEBUG_ENABLE 1
#if DEBUG_ENABLE > 0
#define DEBUG_PORT UART_PORT1
#define DBG_BUF_LEN 512
static char DBG_BUFFER[DBG_BUF_LEN];
#define APP_DEBUG(FORMAT,…) {
Ql_memset(DBG_BUFFER, 0, DBG_BUF_LEN);
Ql_sprintf(DBG_BUFFER,FORMAT,##VA_ARGS);
if (UART_PORT2 == (DEBUG_PORT))
Ql_Debug_Trace(DBG_BUFFER);
} else {
Ql_UART_Write((Enum_SerialPort)(DEBUG_PORT), (u8*)(DBG_BUFFER), Ql_strlen((const char *)(DBG_BUFFER)));
#else
#endif
static u8 Serial_Buffer[1024];
bool reset=FALSE;
#define LOGIC_WTD1_TMR_ID (TIMER_ID_USER_START + 1)
#define LOGIC_WTD2_TMR_ID (TIMER_ID_USER_START + 2)
static void callback_onTimer(u32 timerId, void* param);
static void CallBack_UART_Hdlr(Enum_SerialPort port, Enum_UARTEventType msg, bool level, void* customizedPara);
main task
void proc_main_task(s32 TaskId)
ST_MSG msg;
s32 wtdid;
s32 ret;// Register & open UART port
ret = Ql_UART_Register(UART_PORT1, CallBack_UART_Hdlr, NULL);
if (ret < QL_RET_OK)
APP_DEBUG(“Fail to register serial port[%d], ret=%d\r\n”, UART_PORT1, ret);
ret = Ql_UART_Open(UART_PORT1, 115200, FC_NONE);
APP_DEBUG(“Fail to open serial port[%d], ret=%d\r\n”, UART_PORT1, ret);
}APP_DEBUG("\r\n<–OpenCPU: watchdog TEST!–>\r\n");
// Initialize external watchdog:
// specify the GPIO pin (PINNAME_NETLIGHT) and the overflow time is 600ms.
ret = Ql_WTD_Init(0, PINNAME_GPIO0, 300);
if (0 == ret)
APP_DEBUG("\r\n<–OpenCPU: watchdog init OK!–>\r\n");
}// Create a logic watchdog, the interval is 3s
wtdid = Ql_WTD_Start(3000);// Register & start a timer to feed the logic watchdog.
// The watchdog id will be passed into callback function as parameter.
ret = Ql_Timer_Register(LOGIC_WTD1_TMR_ID, callback_onTimer, &wtdid);
if(ret < 0)
APP_DEBUG("<–main task: register fail ret=%d–>\r\n",ret);
return;
// The real feeding interval is 2s
ret = Ql_Timer_Start(LOGIC_WTD1_TMR_ID, 1000,TRUE);
if(ret < 0)
APP_DEBUG("<–main task: start timer fail ret=%d–>\r\n",ret);
return;
APP_DEBUG("<–main task: start timer OK ret=%d–>\r\n",ret);while (TRUE)
Ql_OS_GetMessage(&msg);
switch(msg.message)
// Application will receive this message when OpenCPU RIL starts up.
// Then application needs to call Ql_RIL_Initialize to launch the initialization of RIL.
case MSG_ID_RIL_READY:
APP_DEBUG("<-- RIL is ready -->\r\n");
Ql_RIL_Initialize();
// After RIL initialization, developer may call RIL-related APIs in the .h files in the directory of SDK\ril\inc
// RIL-related APIs may simplify programming, and quicken the development.
break;// Handle URC messages. // URC messages include "module init state", "CFUN state", "SIM card state(change)", // "GSM network state(change)", "GPRS network state(change)" and other user customized URC. case MSG_ID_URC_INDICATION: switch (msg.param1) { case URC_COMING_CALL_IND: { ST_ComingCall* pComingCall = (ST_ComingCall*)msg.param2; APP_DEBUG("<-- Coming call, number:%s, type:%d -->\r\n", pComingCall->phoneNumber, pComingCall->type); // Enable module sleep mode ret = Ql_SleepEnable(); APP_DEBUG("\r\n<-- Request sleep mode, ret=%d -->\r\n\r\n", ret); break; } default: //APP_DEBUG("<-- Other URC: type=%d\r\n", msg.param1); break; } break; default: break; }
- the 1st sub task
static void callback_onTimer(u32 timerId, void param)
if(reset==TRUE)
APP_DEBUG("<-- Restarted -->\r\n");
// Ql_Reset(0);
return;
else
s32 wtdid = (s32)param;
Ql_WTD_Feed(*wtdid);
//APP_DEBUG("<-- time to feed logic watchdog (wtdId=%d) -->\r\n",*wtdid);
static s32 ReadSerialPort(Enum_SerialPort port, /[out]/u8* pBuffer, /[in]/u32 bufLen)
s32 rdLen = 0;
s32 rdTotalLen = 0;
if (NULL == pBuffer || 0 == bufLen)
return -1;
Ql_memset(pBuffer, 0x0, bufLen);
while (1)
rdLen = Ql_UART_Read(port, pBuffer + rdTotalLen, bufLen - rdTotalLen);
if (rdLen <= 0) // All data is read out, or Serial Port Error!
break;
rdTotalLen += rdLen;
// Continue to read...
if (rdLen < 0) // Serial Port Error!
APP_DEBUG("Fail to read from port[%d]\r\n", port);
return -99;
return rdTotalLen;
s32 ret;
u32 BufLen=0;
switch (msg)
case EVENT_UART_READY_TO_READ:
char* p = NULL;
char* q = NULL;
Ql_memset(Serial_Buffer, 0x0, sizeof(Serial_Buffer));
BufLen = ReadSerialPort(port, Serial_Buffer, sizeof(Serial_Buffer));
p = Ql_strstr(Serial_Buffer,"RESET");
if (p)
reset=TRUE;
APP_DEBUG("Restart Initiated\r\n");
break;
else
APP_DEBUG("Check Command\r\n");
break;
default:
break;
#endif // EXAMPLE_WATCHDOG
