W5500 Ethernet Module With EC200U And QUECPYTHON
I need a schematic diagram showing how to connect a W5500 Ethernet module to the EC200U module.
Additionally, please provide example QuecPython code that demonstrates how to interface with the W5500 and get it working (e.g., initialize the SPI interface and establish a basic Ethernet connection).
The diagram should clearly show:
  • Power connections
  • SPI pins (MOSI, MISO, SCK, CS)
  • Reset/interrupt pins if required
The example code should include:
  • SPI initialization
  • W5500 initialization
  • Basic network configuration or test communication.
Dear customer
For the usage of the W5500, please refer to the link below.
class W5500 - W5500 Ethernet NIC Control - QuecPython
Ethernet NIC - QuecPython
I’m sorry, but I haven’t been able to find the relevant documentation for the W5500 hardware design. However, the W5500 mainly uses SPI and GPIO pins, so it will work as long as the correct SPI and GPIO pins are used.
SPI – Serial Peripheral Interface Bus Protocol - QuecPython
Pin - Control I/O Pins - QuecPython
