Do anyone know how to make voLTE call on ec200t model if the sim card supports this feature. Do i need to externality configure this setting or which at commands i should use?
Thenks
Thenks
Hi @kaxa_gvimraze
Can you use the AT+QGMR command to look up the current version in use? Because VOLTE is only supported in R03 version.
thanks i will check.
“EC200TEUHAR05A01M16” this is my version so I guess it supports?
Hi @kaxa_gvimraze
Yes it support volte.
thanks you very much
