Voice Over USB + VoLTE + RM502Q-GL
Dear all,
i’ve followed the Quectel_EC2x_EG9x_Voice_Over_USB_and_UAC_Application_Not_V1.0.pdf to enable UAC on my RM502Q-GL (fw version: RM502QGLAAR11A02M4G).
Using AirScreen tool, on the DIAG port I can see that VoLTE is successfully registered, but if i’m trying an inbound call I got:
  • SIP Invite
  • SIP 100 - Trying
  • SIP 486 - Busy Here
So looks like that the module itself doens’t permit to answer the call. I’ve also tried to put it in WCDMA mode, and still no way to get a call. Trying an outgoing call with ATD command give me “NO CARRIER” error (both LTE/CS mode).
Interesting part is that and incoming call (both LTE/CS mode) doesn’t generate “RING” urc on AT port.
May i’m missing something special, or is a problem of the firmware that i’m running?
Thanks in advance
Dear @stich86
Please query firmware via AT+QGMR.
Hi Silvia,
sorry for late reply, here is the output of AT+QGMR command:
RM502QGLAAR11A02M4G_01.001.01.001
@silvia any news?
thanks
Dear @stich86
Do you install the driver? Please don’t follow the steps of LTE module. They have different AT command.
=>For this, you need to check the urc port via AT+QURCCFG=“urcport”.
Your firmware didn’t the latest firmware, please contact with your provider and get the latest one.
@silvia
This module was got by Aliexpress, is it possible to you to share latest firmware?
Dear @stich86
It is better to contact with them firstly.
Hi @silvia ,
i want to start experiment again with this module and Voice.
Do you have update documents to enable it? Because you said that commands are different from LTE variant.
@silvia
I did that command and output was only this:
+QURCCFG: "urcport","usbat"
Then i’ve tried to do:
AT+QURCCFG="urcport"
+QURCCFG: "urcport","all"
Also Voice and Service Domain are set:
AT+QNWPREFCFG="voice_domain"
+QNWPREFCFG: "voice_domain",3
AT+QNWPREFCFG="srv_domain"
+QNWPREFCFG: "srv_domain",2
But still same problem. VoLTE is registered, but when I call the SIM I got 486 busy
Pls let me know if this module can be used and how with voice
@herbert.pan-Q @silvia @Kyson @Kerr.Yang-Q
Any help? If this module cannot support it, just tell me..
I’ll move to another vendor in that case :frowning:
looks like same behaviour for RM520N
So.. just to understand and have an official reply from Quectel: Does these modules support voice?
IMS is registering, UAC can be enabled, but module refuses to receive/make calls..
so after I got RM502QGLAAR11A02M4G_01.200.01.200 from a friend, the module now generate the correct output but.. when an incoming call is received (over VoLTE) ATA command doesn’t work.
If i switch voice domain over CS Only with the command AT+QNWPREFCFG="voice_domain",0 it will respond..
and UAC is not working as expected, no audio is coming from the NMEA port
what the hell :\
another test.. in CS mode, after answer i’ve tested AT+QLTONE=1,1000,200,300,3000 that should send DTMF tone, but no signal on remote party
looks like that audio is not working as expected, same problem from another topic: RM502 sends always zeroes to o PCM stream
it’s a bug (hope not a feature) :smiley:
@Duncan.Xu-Q may be you can help..
Hi Stich86,
if you want test DTMF tone in a voice call, you can try AT+VTS command, thx.
Hi @Duncan.Xu-Q
As I’ve said, I tried that command but there is no audio (in both way)
And in VoLTE mode isn’t possible to answer any call.. there is a bug in that firmware for sure (01.200 build)
