I want to use one of the serial devices available at the USB bus for my own OpenCPU app. I have no idea, how to do this. Can someone give me a hint or an example.
background:
In stock firmware A07 or A10 there are 2 serial devices appear my system after the module has booted. But there seams no functionionality behind this. I tried every possible AND impossible baudrate…
After uploading my own app (out of SDK 1.5) it works flawless on UART_PORT0 which is hardware “main” uart. Meanwhile the both USB serial devices becoming alive and sending a lot trace messages from system @115200 baud.
I tried to modify debug port setting in custom_sys_cfg.c and try all possible uarts from Enum_SerialPort in my app. …no luck
Can someone show me the magic using virtual com port on USB?
Thank you in advance!
