Using RM520N-GL over PCI Slot with ARM64 MAchine
Hello Team,
I have been using the RM520N-GL modem for a project and have primarily operated it through the USB interface. I sent AT commands over the ttyUSB2 device node to control the device. However, as my project now requires using the PCI slot, I would like to seek guidance on how to migrate PCI Interface.
To provide more context, my Linux machine is ARM64-based and running on a Yocto image and supports PCI-EP mode.
From the AT command manual of the modem, I found a couple of commands that can be used to switch the modem to PCI mode, which are as follows:
AT+QCFG=“data_interface”,1,0 (to set the interface to PCI)
AT+QCFG=“pcie/mode”,1 (set the PCI RC mode)
Are these commands sufficient to switch the modem from USB to PCIe mode? Additionally, I have the Quectel_Linux_PCIE_MHI_Driver_V1.3.7 driver, Could you please clarify the specific use case of this MHI driver for my Quectel modem in the PCIe configuration?
Thanks & Regards,
Suresh Kumar
Here is the corrected version:
To provide more context, my Linux machine is ARM64-based and running on a Yocto image and supports PCI-RC device.
You should set the modem to PCIE EP mode.
AT+QCFG=“pcie/mode”,0
Hi Bean Wang-Q,
We tried the suggested configuration AT+QCFG=“PCIe/mode”,0, but nothing was listed on the lscpci command or in the kernel message.
The PCIE device do not support hotplug. If the RM520N-GL boot too earlier or too late, the host cannot recognize the PCIe device.
The pcie host cannot recognize the PCIE EP device, it has nothing to do with the MHI driver.
the host device is powered ON from the main supply, so when the host device gets the power, it means the modem will also get power from the PCI port, so we are thinking that during the PCI port scanning from PCI RC device, which is our host device, will scan the modem device, which is set as PCI EP device. How can we know that the boot timings are not matched between the device?
then how can we know that modem which is attached to PCI port, because we can only if device is attached or not, using “lspci” command.
Right now, we are not getting any device listed in “lspci” command in UNIX/LINUX system.
Could you show me
lspci
and dmesg log?
Right now you cannot see any pcie device there? Are you sure the PCIE RC works well?
Hello Wang,
I have attached the snapshots of the dmesg for PCI and also shared the list of PCI devices using PCI devices. You can see in the “lspci” command that the PCI RC device, which is the MediaTek 510 Genio EVK kit, is showing a PCI bridge and a PCI-based Wi-Fi adapter, but it is not showing the Quectel modem, which is connected to the PCI slot.
MicrosoftTeams-image (25)
A few more questions, related to AT commands, related to the configuration of the Quectel modem, we have used an ARM64 system to configure the Quectel modem. We have attached the Quectel modem to ARM64 device, used ttyUSB port to configure the AT command, which were,
AT+QCFG=“pcie/mode”,0 (set the PCI EP mode)
then save the user configuration, removed the Quectel modem from USB port, then attached the PCI port of the Quectel modem to PCI port of ARM64 device, and there was no listing of modem.
Is there any mistake in sequence that we are following?
Hello Wang,
Please check the output logs of PCI in the dmesg. Link of the image: https://imgbb.com/RzJK2pr
This image is of lspci log. Link: https://ibb.co/x1JQNQT
There is nothing wrong about the settings.
Maybe you can check the power sequence.
If the host do not pull the PCIE_RST at that time, the host cannot recognize the modem.
For some Mediatek Chip, the chip do not support PCIe MSI interrupt. And the RM520N do not work.
@sureshpawan2010 @karnatamantya Did it work for you eventually? What made the difference to work, or did you choose another way, or give up
Does anyone try to get success on detecting module on PCIe !?
