I am using LC86G module. I want to use multiple GNSS constellations. As far I understand PAIR066 will allow me to set whatever constellation I want to use. Do I need to do anything after that ? Will the output data in NMEA messages be automatically start updating based on selection in PAIR066 command ?
kindly suggest.
Hi N_N,
You can send PAIR513 to save the PAIR066 configuration in flash. So that you don’t need to send PAIR066 every time module back to work from a completely power off.
PAIIR066 will take effect immediately after the command is sent successfully.
Best regards.
