I am using EPAT to capture BC660K-GL module’s log, but all of the logs are encoded.
UE ver. 0x00000000
PC ver. 0x65084851
UE ver. 0x00000000
PC ver. 0x65084851
pls run
ATI
AT+QGMR
Quectel_Ltd
Quectel_BC660K-GL
Revision: BC660KGLAAR01A05_01.200.01.200
Quectel_EPAT操作指导与参考(CN&EN)_BC260Y&BC660K&BC28F&BC95GF&BC300Y&BC950K.pdf (2.1 MB)
You need to load the DB file, refer to the documentation
I have sent you the DB file, which is included in the firmware package
hi dear
could u send DB file for
Quectel_Ltd
Quectel_BC660K-GL
for me
tanks
pls run to query detail version
AT+QGMR
Hi dear
ok
AT+QGMR
Quectel_Ltd
Quectel_BC660K-GL
Hi, @herbert.pan-Q ,
I’m also using the BC660K-GL module and I would like to receive the database file. Would you be able to send it to me?
Thanks in advance
I forgot to include the following info:
AT+QGMR
Quectel_Ltd
Quectel_BC660K-GL
Revision: BC660KGLAAR01A05_01.205.01.205
Thanks, @herbert.pan-Q!
Would it also be possible to receive the same kind of zip file for the BG770A-GL module?
I am not sure if I already have the latest firmware version from it, so I leave here the info provided from this module:
AT+QGMR
BG770AGLAAR01A05_01.200.01.200
ATI
BG770A-GL
Revision: BG770AGLAAR01A05
Best regards
EPAT is not applicable to BG770A. I have sent them to you
Thank you, once again.
