Is it possible to use DTLS on a BC66 module?
I know it is implemented in LWM2M protocol but I prefer to use my own protocol.
Can you specify what application protocol you need to use?
I am using coap over UDP
Quectel_BC66&BC66-NA_CoAP_Application_Note_V1.0.pdf (309.2 KB)
BC66 only supports psk mode of DTLS
What if we use only DTLS without coap, is it possible to use x509 certificates?
X509 certificate mode is temporarily not supported
Ok thanks, do you have documentation for using COAP with low power modes?
I noticed that I need to update the module to use these commands. Can you send me the latest firmware and qflash tool?
I have sent them to you
Hi, I didn’t receive anything
Can you provide a valid email address?
