I’m trying use AT+NCSEARFCN, but after using this I can not connect
Signal power:-32768
Total power:-32768
TX power:-32768
TX time:0
RX time:0
Cell ID:4294967295
ECL:255
SNR:-32768
EARFCN:4294967295
PCI:65535
RSRQ:-32768
OPERATOR MODE:0
CURRENT BAND:255
it’s possible that stored EARFCN values are cleared forever?
what can I do?
hi, Leila_Ghanbari:
This “AT Command” is primarily used to clear frequency points that were previously registered on the network in the MODEM.at the same time,This command is only valid after “AT+CFUN=0” is executed.
After that, you need to follow the following “AT+Command”:
AT+CFUN=1
AT+CGATT=1
Thanks, I know that, but after execution this command I can get IP. I use band 3, before this command my band was 3, but now I have this
Signal power:-32768
Total power:-32768
TX power:-32768
TX time:0
RX time:35438
Cell ID:4294967295
ECL:255
SNR:-32768
EARFCN:4294967295
PCI:65535
RSRQ:-32768
OPERATOR MODE:0
CURRENT BAND:255
hi, Leila_Ghanbari:
I suggest you try using the following command, if there are still errors, you shall upload the results of the error, I will double check.
AT+NUESTATS=CELL
AT+NUESTATS=RADIO
AT+NUESTATS=RADIO
NUESTATS:RADIO,Signal power:-32768
NUESTATS:RADIO,Total power:-32768
NUESTATS:RADIO,TX power:-32768
NUESTATS:RADIO,TX time:0
NUESTATS:RADIO,RX time:0
NUESTATS:RADIO,Cell ID:4294967295
NUESTATS:RADIO,ECL:255
NUESTATS:RADIO,SNR:-32768
NUESTATS:RADIO,EARFCN:4294967295
NUESTATS:RADIO,PCI:65535
NUESTATS:RADIO,RSRQ:-32768
NUESTATS:RADIO,OPERATOR MODE:0
NUESTATS:RADIO,CURRENT BAND:255
I think this happened after applying AT+NCSEARFCN Clear Stored EARFCN
after that i try to use AT+NEARFCN=0,1790, but not work
hi, Leila_Ghanbari:
Do any other “AT Command” cause unusual problems?
I believe that your device has registered the network successfully now. However, it is not possible to find out the cause of this problem at present. I suggest you restart the device or update the firmware (if necessary).
Thank you Herbert, I update the firmware, but it’s not solved. I’m very confused.
Well, it’s amazing, I’m also very confused if you update the firmware;If your device is working well, I suggest you continue to use it, the above problems do not affect the performance of the device;But if you care enough, you’ll need to describe the problem in detail and send an email to support@quectel.com
