Hello Martin,
Thanks for your question.
About your first question, we have reference design including it, please refer to it.
About your second question, we have AT+QETH=“speed” that can lower speed.
BTW, in order to better support you, please answer below questions, thanks!
Company name:
R&D location:
Project name (so we can refer to it in the future):
Thank you for your Response
I’m a Student from the Karlsruher Institute of Technology in Germany and we plan to do some tests at a 5G Campus-Network with the RG500Q.
So how should I connect a MAC to RG500Q to use it as a 5G PHY?
Maybe this is not possible, so my question, what purpose is the RGMII-Interface of the Module meant for?
My second Question was about connecting an MII with the RGMII.
The HP Specs of the RGMII (HP Specs of the RGMII) defines in 5.0 that the RGMII can be used as an MII by changing it to 10/100 Functionality. So its great, that I can change the speed of the RGMII, but how do I connect those Interfaces.
(especially the RGMII_CTL_TX line to the TX_EN and TX_ER of the MII, and the RGMII_CTL_RX to the RX_DV and RX_ER of the MII)
Do I still have to configure the module via USB or PCI?
And do I recieve/send standard Ethernet-MAC protocolls?
Is this even possible?
